Luke 42242 Posted October 8, 2025 Posted October 8, 2025 1 hour ago, Phalcon said: The new beta 4.9.2.1 finally fixed it! It has an updated Intel driver.
EHRETic 7 Posted October 8, 2025 Posted October 8, 2025 2 hours ago, Phalcon said: The new beta 4.9.2.1 finally fixed it! I can confirm, working for me too 1
philliml74 0 Posted October 8, 2025 Posted October 8, 2025 I take it that the .deb package hasn't been released yet and you guys are building from source?
Luke 42242 Posted October 8, 2025 Posted October 8, 2025 15 minutes ago, philliml74 said: I take it that the .deb package hasn't been released yet and you guys are building from source? Hi, it will be coming. Thanks. 1
philliml74 0 Posted October 8, 2025 Posted October 8, 2025 15 minutes ago, philliml74 said: I take it that the .deb package hasn't been released yet and you guys are building from source? Ahh, you guys are running from a docker container not from a .deb package. I just found the docker 4.9.2.1 releases.
philliml74 0 Posted October 9, 2025 Posted October 9, 2025 5 hours ago, Phalcon said: The new beta 4.9.2.1 finally fixed it! Can confirm the Emby Server 4.9.2.1 beta (in docker) does fix the transcoding issue.
EHRETic 7 Posted October 9, 2025 Posted October 9, 2025 9 hours ago, philliml74 said: Ahh, you guys are running from a docker container not from a .deb package. I just found the docker 4.9.2.1 releases. Yes! I have several instances, also Plex and Jellyfin on the same physical server. With that setup I can test things without breaking the ones used by family... @Lukewill this change be integrated in 4.8 version?
Luke 42242 Posted October 9, 2025 Posted October 9, 2025 9 hours ago, EHRETic said: Yes! I have several instances, also Plex and Jellyfin on the same physical server. With that setup I can test things without breaking the ones used by family... @Lukewill this change be integrated in 4.8 version? It will be back ported eventually to 4.9 stable once it has had more time on the beta channel. We won't be doing another 4.8 release though.
EHRETic 7 Posted October 9, 2025 Posted October 9, 2025 37 minutes ago, Luke said: It will be back ported eventually to 4.9 stable once it has had more time on the beta channel. We won't be doing another 4.8 release though. The "dumb" question everybody asked already : any ETA for 4.9?
Luke 42242 Posted October 9, 2025 Posted October 9, 2025 7 minutes ago, EHRETic said: The "dumb" question everybody asked already : any ETA for 4.9? HI, it is already available.
EHRETic 7 Posted October 9, 2025 Posted October 9, 2025 30 minutes ago, Luke said: HI, it is already available. Whaaat, not beta ?!? How did I miss that ? 1
EHRETic 7 Posted October 12, 2025 Posted October 12, 2025 On 10/9/2025 at 9:14 PM, Luke said: HI, it is already available. Tested, but 4.9 is still beta. "latest" tag is still a 4.8 so even if you have a very high quality check, 4.9 is still not the productive version! 1
elfloko 0 Posted October 13, 2025 Posted October 13, 2025 Unfortunately, it still doesn't work for me. Current beta version in OMV7... services: emby: image: emby/embyserver:beta container_name: embyserver network_mode: host # Enable DLNA and Wake-on-Lan environment: - TZ=Europe/Vienna - UID=1001 # The UID to run emby as (default: 2) - GID=100 # The GID to run emby as (default 2) - GIDLIST=100 # A comma-separated list of additional GIDs to run emby as (default: 2) volumes: - /srv/composer/embyserver/programdata:/config # Configuration directory - /srv/Media/Serien:/mnt/share1 # Media directory - /srv/Media/Filme:/mnt/share2 # Media directory ports: - 8096:8096 # HTTP port devices: - /dev/dri:/dev/dri - /dev/dri/card0:/dev/dri/card0 - /dev/dri/renderD128:/dev/dri/renderD128 restart: on-failure
Q-Droid 1011 Posted October 13, 2025 Posted October 13, 2025 You need a Linux kernel version that is new enough to support this CPU. Some sources say 6.9 others say 6.11. If you can update OMV7 to kernel 6.11+ you will at least cover that requirement. 1
MSDaniel 5 Posted October 13, 2025 Posted October 13, 2025 Is anyone successfully using hardware transcoding with the latest Emby beta on Unraid 7.1.4 and Intle N150? Does not work for me... Am I missing something?
Enrico1203 14 Posted October 14, 2025 Posted October 14, 2025 On 09/10/2025 at 21:14, Luke said: HI, it is already available. ffmpeg-transcode-a8965f5c-5984-4bc0-b941-576d17781412_1.txtffmpeg-transcode-df98f440-c9a0-44ee-94a6-9326102cbf6a_1.txtembyserver (1).txt I installed the 4.9.2.3 beta but the hardware transcoding still fails. I attach the full logs.
Enrico1203 14 Posted October 14, 2025 Posted October 14, 2025 7 hours ago, Enrico1203 said: ffmpeg-transcode-a8965f5c-5984-4bc0-b941-576d17781412_1.txtffmpeg-transcode-df98f440-c9a0-44ee-94a6-9326102cbf6a_1.txtembyserver (1).txt I installed the 4.9.2.3 beta but the hardware transcoding still fails. I attach the full logs. To exclude any problems with my system i run this test and works with qsv: root@Debian-trixie-latest-amd64-base ~/temp # docker run --rm -it --device=/dev/dri:/dev/dri -v $(pwd):/config linuxserver/ffmpeg -hwaccel qsv -i /config/produzione_corretto.mkv -c:v hevc_qsv /config/output_finale_qsv.mkv **** creating video group videocqyx with id 992 **** **** adding /dev/dri/renderD128 to video group videocqyx with id 992 **** **** adding /dev/dri/card0 to video group video with id 44 **** ffmpeg version 8.0 Copyright (c) 2000-2025 the FFmpeg developers built with gcc 13 (Ubuntu 13.3.0-6ubuntu2~24.04) configuration: --disable-debug --disable-doc --disable-ffplay --enable-alsa --enable-cuda-llvm --enable-cuvid --enable-ffprobe --enable-gpl --enable-libaom --enable-libass --enable-libdav1d --enable-libfdk_aac --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-libkvazaar --enable-liblc3 --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libplacebo --enable-librav1e --enable-librist --enable-libshaderc --enable-libsrt --enable-libsvtav1 --enable-libtheora --enable-libv4l2 --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpl --enable-libvpx --enable-libvvenc --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-nonfree --enable-nvdec --enable-nvenc --enable-opencl --enable-openssl --enable-stripping --enable-vaapi --enable-vdpau --enable-version3 --enable-vulkan libavutil 60. 8.100 / 60. 8.100 libavcodec 62. 11.100 / 62. 11.100 libavformat 62. 3.100 / 62. 3.100 libavdevice 62. 1.100 / 62. 1.100 libavfilter 11. 4.100 / 11. 4.100 libswscale 9. 1.100 / 9. 1.100 libswresample 6. 1.100 / 6. 1.100 [vist#0:0/hevc @ 0x55800b96ac40] WARNING: defaulting hwaccel_output_format to qsv for compatibility with old commandlines. This behaviour is DEPRECATED and will be removed in the future. Please explicitly set "-hwaccel_output_format qsv". Input #0, matroska,webm, from '/config/produzione_corretto.mkv': Metadata: COMPATIBLE_BRANDS: isommp41mp42 MAJOR_BRAND : mp42 MINOR_VERSION : 1 ENCODER : Lavf62.3.100 Duration: 00:02:45.90, start: 0.000000, bitrate: 715 kb/s Stream #0:0: Video: hevc (Main), yuv420p(tv, bt709/bt709/unknown, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 30 fps, 30 tbr, 1k tbn, start 0.003000 (default) Metadata: ENCODER : Lavc62.11.100 libx265 HANDLER_NAME : Core Media Video VENDOR_ID : [0][0][0][0] DURATION : 00:02:45.903000000 Stream #0:1: Audio: vorbis, 48000 Hz, stereo, fltp (default) Metadata: ENCODER : Lavc62.11.100 libvorbis HANDLER_NAME : Core Media Audio VENDOR_ID : [0][0][0][0] DURATION : 00:02:45.848000000 libva info: VA-API version 1.22.0 libva info: Trying to open /usr/local/lib/x86_64-linux-gnu/dri/iHD_drv_video.so libva info: Found init function __vaDriverInit_1_22 libva info: va_openDriver() returns 0 libva info: VA-API version 1.22.0 libva info: Trying to open /usr/local/lib/x86_64-linux-gnu/dri/iHD_drv_video.so libva info: Found init function __vaDriverInit_1_22 libva info: va_openDriver() returns 0 File '/config/output_finale_qsv.mkv' already exists. Overwrite? [y/N] y Stream mapping: Stream #0:0 -> #0:0 (hevc (hevc_qsv) -> hevc (hevc_qsv)) Stream #0:1 -> #0:1 (vorbis (native) -> vorbis (libvorbis)) Press [q] to stop, [?] for help [hevc_qsv @ 0x55800b9a96c0] Using the constant quantization parameter (CQP) by default. Please use the global_quality option and other options for a quality-based mode or the b option and other options for a bitrate-based mode if the default is not the desired choice. Output #0, matroska, to '/config/output_finale_qsv.mkv': Metadata: COMPATIBLE_BRANDS: isommp41mp42 MAJOR_BRAND : mp42 MINOR_VERSION : 1 encoder : Lavf62.3.100 Stream #0:0: Video: hevc, qsv(tv, bt709/bt709/unknown, progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 30 fps, 1k tbn (default) Metadata: encoder : Lavc62.11.100 hevc_qsv HANDLER_NAME : Core Media Video VENDOR_ID : [0][0][0][0] DURATION : 00:02:45.903000000 Side data: cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: N/A Stream #0:1: Audio: vorbis (oV[0][0] / 0x566F), 48000 Hz, stereo, fltp (default) Metadata: encoder : Lavc62.11.100 libvorbis HANDLER_NAME : Core Media Audio VENDOR_ID : [0][0][0][0] DURATION : 00:02:45.848000000 [out#0/matroska @ 0x55800b9bce40] video:5317KiB audio:1657KiB subtitle:0KiB other streams:0KiB global headers:4KiB muxing overhead: 1.572626% frame= 4977 fps=618 q=-0.0 Lsize= 7083KiB time=00:02:45.76 bitrate= 350.0kbits/s speed=20.6x elapsed=0:00:08.05
Enrico1203 14 Posted October 15, 2025 Posted October 15, 2025 I managed to solve my problems. If someone have the same issue i did this on my debian 13: wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/i915/mtl_guc_70.bin wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/i915/mtl_dmc.bin sudo mv mtl_guc_70.bin /lib/firmware/i915/ sudo mv mtl_dmc.bin /lib/firmware/i915/ reboot the system
Cobester 3 Posted October 24, 2025 Posted October 24, 2025 (edited) For those using latest Intel 15th gen CPUs can confirm that HW transcoding works out of the box on v4.9.2.4. QuickSync is also detected and HW tone mapping also works. Running Emby in Docker under a Proxmox LXC container. Intel Core Ultra 5 225H CPU. Edited October 24, 2025 by Cobester 1
madblam 3 Posted October 25, 2025 Posted October 25, 2025 14 hours ago, Cobester said: For those using latest Intel 15th gen CPUs can confirm that HW transcoding works out of the box on v4.9.2.4. QuickSync is also detected and HW tone mapping also works. Running Emby in Docker under a Proxmox LXC container. Intel Core Ultra 5 225H CPU. Can you share your docker compose as well? I am still having an issue with my Intel Core Ultra 5 225H CPU.
EHRETic 7 Posted October 25, 2025 Posted October 25, 2025 15 hours ago, Cobester said: For those using latest Intel 15th gen CPUs can confirm that HW transcoding works out of the box on v4.9.2.4. QuickSync is also detected and HW tone mapping also works. On my end, I could not make QuickSync work, even if detected in the admin console. Only VAAPI works fine. Current used version : 4.2.9.6 for a test instance and 4.9.1.80 for my "prod"
Cobester 3 Posted November 5, 2025 Posted November 5, 2025 On 25/10/2025 at 23:37, madblam said: Can you share your docker compose as well? I am still having an issue with my Intel Core Ultra 5 225H CPU. Hope this helps services: emby: # image: rajiska/emby-n150-fixed # image: emby/embyserver image: emby/embyserver:4.9.2.4 # Workaround emby image with latest intel-media drivers container_name: embyserver # runtime: nvidia # Expose NVIDIA GPUs network_mode: host # Enable DLNA and Wake-on-Lan environment: - UID=0 # The UID to run emby as (default: 2) - GID=0 # The GID to run emby as (default 2) - GIDLIST=44,104 # A comma-separated list of additional GIDs to run emby as (default: 2) volumes: - ${EMBY_CONFIG_PATH}:/config # Configuration directory - ${EMBY_MEDIA_PATH}:/mnt/ent # Media directory ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes restart: on-failure
madblam 3 Posted November 16, 2025 Posted November 16, 2025 On 06/11/2025 at 00:11, Cobester said: Hope this helps services: emby: # image: rajiska/emby-n150-fixed # image: emby/embyserver image: emby/embyserver:4.9.2.4 # Workaround emby image with latest intel-media drivers container_name: embyserver # runtime: nvidia # Expose NVIDIA GPUs network_mode: host # Enable DLNA and Wake-on-Lan environment: - UID=0 # The UID to run emby as (default: 2) - GID=0 # The GID to run emby as (default 2) - GIDLIST=44,104 # A comma-separated list of additional GIDs to run emby as (default: 2) volumes: - ${EMBY_CONFIG_PATH}:/config # Configuration directory - ${EMBY_MEDIA_PATH}:/mnt/ent # Media directory ports: - 8096:8096 # HTTP port - 8920:8920 # HTTPS port devices: - /dev/dri:/dev/dri # VAAPI/NVDEC/NVENC render nodes restart: on-failure Can you confirm my understanding that you have a dedicated nvidia GPU on your machine? Or why is it here have it here if you are using your Intel Core Ultra 5 225H? Thanks for your help
