user84 46 Posted December 18, 2024 Posted December 18, 2024 I'd like to wipe my library and start from scratch, but not lose the settings I've worked hard to set up in the emby server. Is it possible to restore backed up settings without restoring library information?
Carlo 4561 Posted December 18, 2024 Posted December 18, 2024 Hi, Why don't you just delete the library and start over with it? Carlo
user84 46 Posted December 18, 2024 Author Posted December 18, 2024 2 hours ago, Carlo said: Hi, Why don't you just delete the library and start over with it? Carlo Is it possible to do that without deleting my server settings?
Solution Luke 42183 Posted December 19, 2024 Solution Posted December 19, 2024 Hi, the best thing to do would be to remove all libraries from emby library setup, and let the library scan flush them out of the database. 1
pwhodges 2023 Posted December 19, 2024 Posted December 19, 2024 12 hours ago, Blam84 said: Is it possible to do that without deleting my server settings? What settings do you mean? If they are central settings like network setup and so on, then just removing libraries will not affect them. If they are your library settings, then deleting the library will lose them, but deleting the contents of the library will not. Paul 1
