Gryzor 27 Posted December 9, 2024 Posted December 9, 2024 Hello! Premiere here, not sure if it makes any difference but anyhow. I am unable to adjust playback speed, but *only* when playing back on my Xiaomi 6 pad. When I play the same video files on my Pixel 7 Pro I can always adjust it. I don't use transcoding, quality is always direct/auto, in the same LAN, same conditions. Am I missing something I should look at? Thanks!
Luke 42242 Posted December 9, 2024 Posted December 9, 2024 Hi, what version of the Emby app are you running?
Gryzor 27 Posted December 9, 2024 Author Posted December 9, 2024 1 minute ago, Luke said: Hi, what version of the Emby app are you running? 3.4.20 .
Luke 42242 Posted December 9, 2024 Posted December 9, 2024 That's really odd because it should be there in the menu. Is it not?
Gryzor 27 Posted December 9, 2024 Author Posted December 9, 2024 20 minutes ago, Luke said: That's really odd because it should be there in the menu. Is it not? You mean the speed menu? Yes it's there, but choosing any value does nothing, it always plays back at 1.0x
Gryzor 27 Posted December 9, 2024 Author Posted December 9, 2024 Just now, Luke said: Are you sure it is direct playing? I'm not sure it actually does so, but I'm sure that's the option I have selected (always)
Luke 42242 Posted December 13, 2024 Posted December 13, 2024 OK . Let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Gryzor 27 Posted December 13, 2024 Author Posted December 13, 2024 1 minute ago, Luke said: OK . Let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Let me check tonight, because laser night a plugin was updated and I restarted my server, and I saw it fast forwarding for the first time! So I'll see if it persists. 1
ebr 16335 Posted December 13, 2024 Posted December 13, 2024 What is the audio format? Bitstreamed codecs (DD, DTS, etc.) cannot be speed adjusted without transcoding.
Gryzor 27 Posted December 13, 2024 Author Posted December 13, 2024 4 minutes ago, ebr said: What is the audio format? Bitstreamed codecs (DD, DTS, etc.) cannot be speed adjusted without transcoding. Yeah I know, but: -although I haven't checked, this has been the case with lots of different files, there's bound to have been one that would be doable -same files could be sped up on my phone.
ebr 16335 Posted December 13, 2024 Posted December 13, 2024 11 minutes ago, Gryzor said: same files could be sped up on my phone They may have been going through ffmpeg. We'll have to look at a specific example to know for sure.
Gryzor 27 Posted December 13, 2024 Author Posted December 13, 2024 1 minute ago, ebr said: They may have been going through ffmpeg. We'll have to look at a specific example to know for sure. But as I said in OP, same conditions and settings everywhere, and always Direct...
ebr 16335 Posted December 13, 2024 Posted December 13, 2024 1 hour ago, Gryzor said: and always Direct... Some of the apps can direct play but mix down a track internally so that it can be speed adjusted. A specific example will remove all speculation though.
Gryzor 27 Posted December 13, 2024 Author Posted December 13, 2024 Just confirmed it's changing speed now, maybe the server restart indeed helped. Tomorrow I'll try to locate one of the files that presented the problem. 1
