Asazen 8 Posted December 10, 2024 Author Posted December 10, 2024 24 minutes ago, Luke said: If you remove the configuration altogether, then the server will reset it back to the default value. Instead, keep SortRemoteWords, but don't have any strings inside. I just tried it that way too, and I realized that after restarting emby with that file edited, the server does not start.
Happy2Play 9811 Posted December 10, 2024 Posted December 10, 2024 13 minutes ago, Asazen said: I just tried it that way too, and I realized that after restarting emby with that file edited, the server does not start. What exactly did you do? <RemoveSortWords /> or <SortRemoveWords></SortRemoveWords> Shutdown Emby change system.xml, start Emby and Refresh metadata.
Asazen 8 Posted December 10, 2024 Author Posted December 10, 2024 19 minutes ago, Happy2Play said: What exactly did you do? <RemoveSortWords /> or <SortRemoveWords></SortRemoveWords> Shutdown Emby change system.xml, start Emby and Refresh metadata. I turn off emby, edit the xml and emby no longer starts
Happy2Play 9811 Posted December 10, 2024 Posted December 10, 2024 1 minute ago, Asazen said: I turn off emby, edit the xml and emby no longer starts Probably need to see the server log then. Only guess may be permissions changed.
Asazen 8 Posted December 10, 2024 Author Posted December 10, 2024 Once I restore the original xml, emby starts immediately, apparently it doesn't want me to edit it.
Luke 42241 Posted December 10, 2024 Posted December 10, 2024 18 minutes ago, Asazen said: Once I restore the original xml, emby starts immediately, apparently it doesn't want me to edit it. No, this generally just means the hand editing resulted in malformed xml. It's a good idea to run it through an xml validator before trying to start the server.
Asazen 8 Posted December 11, 2024 Author Posted December 11, 2024 21 hours ago, Luke said: No, this generally just means the hand editing resulted in malformed xml. It's a good idea to run it through an xml validator before trying to start the server. I think I understand that it tells me that the xml is correct, but the server still does not start. I hope you can give me some joy and incorporate it into the emby control panel in the next version.
Luke 42241 Posted December 12, 2024 Posted December 12, 2024 HI, yes we should get this added to the server web UI. Thanks. 1
