rk-mks@web.de 2 Posted December 5, 2024 Posted December 5, 2024 Hello, I have following Problem on my DS224 with 7.2xxx DSM When i restart my NAS, Embyserver is not started automaticly. When i click on the Emby Icon Server starts without any Problem. Now i try to add a script to Scheduler but dont know how to start the Server over Command-Line. Could somebody maybe point to way to handle this Problem ? Thanks Rainer
Carlo 4561 Posted December 6, 2024 Posted December 6, 2024 Hi, You shouldn't need to do that. What I would try is remove the Emby Server via Package Manager. Do not delete or change any files on disk. All your config, users, library, etc is still there. Install Emby Server again. By uninstalling and reinstalling, your problem may be fixed. Emby Server should start by itself when the NAS is restarted. Carlo 1
rk-mks@web.de 2 Posted December 6, 2024 Author Posted December 6, 2024 Hello Carlo, Yeah this works, perfect.... Sometimes it's so easy, just thinking to complicated.... Thank you for your Support Rainer 2
Carlo 4561 Posted December 8, 2024 Posted December 8, 2024 On 12/6/2024 at 2:52 AM, rk-mks@web.de said: Hello Carlo, Yeah this works, perfect.... I had a feeling it would fix it. Glad it worked for you.
