oceanclub 12 Posted November 30, 2024 Posted November 30, 2024 Any reason a file with this sound would lag or even skip on the XBox One app. Works fine if played on Windows. Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 1 h 59 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 549 MiB (11%) Language : English Service kind : Complete Main Default : No Forced : No
Luke 42289 Posted November 30, 2024 Posted November 30, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
oceanclub 12 Posted November 30, 2024 Author Posted November 30, 2024 Hey, ignore this - turns out my server had updated but the service had not restarted (I'm running as a service). Stopping and restarting the service fixed the lag. P. 1
