TheShanMan 41 Posted November 29, 2024 Posted November 29, 2024 I'm running into this today with a football game. Skipping forward or back doesn't work and the buttons don't appear on the info display at the bottom of the screen. I wasn't recording so I thought maybe if I started recording it would work, but that didn't help (incidentally I don't see it listed in Recordings but it says it's recording). Yesterday watching football it did work. I have no idea what's different other than being on a different channel. I haven't used live TV in several years so I have no idea if this is a longstanding problem or not.
Luke 42234 Posted November 29, 2024 Posted November 29, 2024 @TheShanMan Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
TheShanMan 41 Posted November 30, 2024 Author Posted November 30, 2024 Server log attached. The game started at 9, and to reiterate, initially I was just watching as non-recorded live TV. Around 9:20 I decided to try recording it to see if that solved the problem. I do see a couple errors in the log. Hopefully that helps. Thank you! embyserver.txt
TheShanMan 41 Posted December 2, 2024 Author Posted December 2, 2024 @Lukelooks like you haven't seen this yet so perhaps you like to be tagged. No real rush though.
