Koolee 1 Posted November 29, 2024 Posted November 29, 2024 NAS: Synology DS224+, DSM 7.2.2-72806 Update 2 Emby: 4.8.10.0 with Premiere Enable hardware acceleration when available: Advanced But it is blank under "Preferred Hardware Decoders/Encoders I use this way to install Emby https://mariushosting.com/how-to-install-emby-with-hardware-transcoding-on-your-synology-nas/ How could I use hardware transcoding? hardware_detection-63868526968.txt
Luke 42241 Posted November 29, 2024 Posted November 29, 2024 Hi there, please attach the emby server log as well. Thanks.
Koolee 1 Posted November 30, 2024 Author Posted November 30, 2024 embyserver-63868526958.txt embyserver-63868527284.txt
Solution GroDoggo 1 Posted November 30, 2024 Solution Posted November 30, 2024 Hi Koolee, I faced the same issue with my Synology DS224+, but I managed to resolve it with a few adjustments. Here's what worked for me: Connect to your NAS via SSH and run the following command: sudo synogroup --get videodriver This will display the GID for the videodriver group. Note down the GID. Open the YAML configuration file for your Emby Server Docker container and update the GIDLIST value to include the videodriver GID you just retrieved. Credits → https://joshmccarty.com/emby-with-hardware-transcoding-in-docker-on-synology-dsm-7-2/ I hope this helps! 1
Koolee 1 Posted November 30, 2024 Author Posted November 30, 2024 1 hour ago, GroDoggo said: Hi Koolee, I faced the same issue with my Synology DS224+, but I managed to resolve it with a few adjustments. Here's what worked for me: Connect to your NAS via SSH and run the following command: sudo synogroup --get videodriver This will display the GID for the videodriver group. Note down the GID. Open the YAML configuration file for your Emby Server Docker container and update the GIDLIST value to include the videodriver GID you just retrieved. Credits → https://joshmccarty.com/emby-with-hardware-transcoding-in-docker-on-synology-dsm-7-2/ I hope this helps! It works! Thank you. 1
Kurt13 11 Posted December 1, 2024 Posted December 1, 2024 Hi, Sorry for "hijacking" this thread but since it's almost the same, I thought that wasn't necessary to create a new one. I installed (a couple of months ago) Emby on Container Manager (Synology DS920+) and like @KooleeI also followed a guide from Mariushosting. In my case, the difference was that I've done it with Container Manager and (as you can see in the link I add) without HW Transcoding since I didn't have Premiere (which now I have). So, now i can just change the settings on Container Manager to enable the feature, or do I have to delete it and start from the scratch using Portainer like o the guide from Mariushosting? It would be EXTREMELY painful to set up everything again. Thanks!
weyon668 8 Posted December 1, 2024 Posted December 1, 2024 Why are you using container for emby and not install the native package from the App center? 1
Kurt13 11 Posted December 1, 2024 Posted December 1, 2024 (edited) 7 minutes ago, weyon668 said: Why are you using container for emby and not install the native package from the App center? I didn't know, so i followed the guide i mentioned. I think that when i read somewhere that was the best way to use it on the DS920+. Anyway, the question here is not why i'm using these way instead of the native app. Edited December 1, 2024 by Kurt13
weyon668 8 Posted December 1, 2024 Posted December 1, 2024 Yes, but with the native app there are no problems with gpu acceleration. Just install and enjoy it.
Kurt13 11 Posted December 1, 2024 Posted December 1, 2024 4 minutes ago, weyon668 said: Yes, but with the native app there are no problems with gpu acceleration. Just install and enjoy it. I'm trying to avoid start everything from the scratch
weyon668 8 Posted December 1, 2024 Posted December 1, 2024 No problem, never touch a running system 1
Kurt13 11 Posted December 1, 2024 Posted December 1, 2024 I changed the GIDLIST from 2 to 937 (that i got through SSH) but it still doesn't show nothing.
Kurt13 11 Posted December 2, 2024 Posted December 2, 2024 Hi, Is it possible for someone to help me? Thanks
Luke 42241 Posted December 3, 2024 Posted December 3, 2024 Hi, have you followed the examples in our Docker install guide? https://hub.docker.com/r/emby/embyserver
Kurt13 11 Posted December 3, 2024 Posted December 3, 2024 13 minutes ago, Luke said: Hi, have you followed the examples in our Docker install guide? https://hub.docker.com/r/emby/embyserver When i decided to try Emby for the first time, and since i wasn't a Premiere member, i followed this guide so i don't have a properly yaml file to edit. On Container Manager Emby only shows on "Container" and "Image" tab. Now, that i bought Premiere, i went to see his guide for having Emby with HW Transcoding but for that one, he used Portainer. I tried to ask him how to enable it without starting from the scratch, and, as expected, no help received.
weyon668 8 Posted December 3, 2024 Posted December 3, 2024 Just try install the native app without docker and just look if hw works there (shurdown docker first). Then you can choose if you use the native app or loose time with the docker version.
Luke 42241 Posted December 4, 2024 Posted December 4, 2024 3 hours ago, weyon668 said: Just try install the native app without docker and just look if hw works there (shurdown docker first). Then you can choose if you use the native app or loose time with the docker version. Yes this is a helpful test as well, to see if the native package recognizes it first.
Kurt13 11 Posted December 7, 2024 Posted December 7, 2024 Hi, I changed to a proper use of Emby on docker with YAML config, and now it seems to be working. Everything was being shown but I had to point out the path to each library and do a re-scan again. The only issue I'm having, is to set the backup & restore folder. I tried to add a line on YAML with the path to my previous backup folder (outside of the docker folder) with rw, but till now I'm not able to point to it on Emby. Anyway, regarding transcoding, why "stats for nerds" only shows a green symbol for some movies? Both movies I tested are 4K Dolby Vision HEVC TrueHD 7.1. Thanks
Carlo 4561 Posted December 8, 2024 Posted December 8, 2024 Hi, The green box shown above would be the same you would see on the Dashboard. Run your mouse over it and you'll see it means "Hardware Accelerated Encoding..." If it's a transcode without the green box, it will be a CPU based transcode. This will not apply to Direct Play or Direct Stream (Remux) as they don't require transcoding. Carlo
Kurt13 11 Posted December 8, 2024 Posted December 8, 2024 6 hours ago, Carlo said: Hi, The green box shown above would be the same you would see on the Dashboard. Run your mouse over it and you'll see it means "Hardware Accelerated Encoding..." If it's a transcode without the green box, it will be a CPU based transcode. This will not apply to Direct Play or Direct Stream (Remux) as they don't require transcoding. Carlo Watching on a cell phone, and outside the house, it would be a bit difficult to use a mouse. But why the transcode can be on the cpu instead of the GPU (or both)?
Carlo 4561 Posted December 10, 2024 Posted December 10, 2024 Blasphemy I guess that's a good reason! LOL
Kurt13 11 Posted December 10, 2024 Posted December 10, 2024 31 minutes ago, Carlo said: Blasphemy I guess that's a good reason! LOL I hate travelling on highways (and by airplane too), it's way too boring, so sometimes I like to watch something. That's one of the reasons why, sometimes, I use the smartphone/tablet to see something to not cut my wrists. So, do you know why the transcode can be on the cpu instead of the GPU (or both)? Thanks 1
Happy2Play 9811 Posted December 10, 2024 Posted December 10, 2024 23 minutes ago, Kurt13 said: I hate travelling on highways (and by airplane too), it's way too boring, so sometimes I like to watch something. That's one of the reasons why, sometimes, I use the smartphone/tablet to see something to not cut my wrists. So, do you know why the transcode can be on the cpu instead of the GPU (or both)? Thanks Would need to see the ffmpeg log as it should be gpu unless it fails for whatever reason and will fallback to cpu. 1
Kurt13 11 Posted December 10, 2024 Posted December 10, 2024 12 minutes ago, Happy2Play said: Would need to see the ffmpeg log as it should be gpu unless it fails for whatever reason and will fallback to cpu. Tried now 2 times with 2 4K Dolby Vision HEVC TrueHD 7.1 movies (the same ones from my previous post), using my smartphone with 5G. 1st try: One movie didn't show the green symbol but the other did. Also, the 2nd video took some seconds (considerably more than the 1st one) to start playing. 2nd try: Both showed the green symbol. This time, the 2nd video started quickly ffmpeg-transcode-75ba2829-4e88-4184-b579-4b4bc54c0205_1.txt ffmpeg-transcode-da456fd1-507d-4160-9d29-f7d470b17241_1.txt
Happy2Play 9811 Posted December 10, 2024 Posted December 10, 2024 7 minutes ago, Kurt13 said: Tried now 2 times with 2 4K Dolby Vision HEVC TrueHD 7.1 movies (the same ones from my previous post), using my smartphone with 5G. 1st try: One movie didn't show the green symbol but the other did. Also, the 2nd video took some seconds (considerably more than the 1st one) to start playing. 2nd try: Both showed the green symbol. This time, the 2nd video started quickly ffmpeg-transcode-75ba2829-4e88-4184-b579-4b4bc54c0205_1.txt 42.84 kB · 0 downloads ffmpeg-transcode-da456fd1-507d-4160-9d29-f7d470b17241_1.txt 26.99 kB · 0 downloads To me it would be your PGSSUB burn in as it is currently disable in hardware. As the ffmpeg-transcode-da456fd1-507d-4160-9d29-f7d470b17241 log has graphical subs and the other does not. And you see it is slow below 1x conversion speed. Warning: Hardware-accelerated subtitle-overlay is disabled due to diagnostic option >>>>>> Subtitle Processing Steps for [0:3]: HDMV PGS subtitles Step Format Target Size HDMV_PGS_SUBTITLE >> Subs: Bitmap 1920x1080 scale >> Video: UNKNOWN 1920x-2 >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason VAAPI GeminiLake UHD Graphics 600 - H... >> True True Hardware Codec VideoInput >> True True Same adapter (/dev/dri/renderD128), same hardware co... Scaling >> True True ToneMapping (when possible) >> True True SubtitleOverlay >> False False VideoOutput >> True True Hardware encoder VAAPI GeminiLake UHD Graphics 600 - H... >> True True Hardware Codec >>>>>> Video Processing Steps for [0:0]: H.265 (HEVC) Step HW-Context Format SW-Format Size Next HEVC >> VAAPI vaapi_vld yuv420p10 3840x2160 >> scale_vaapi scale_vaapi >> VAAPI vaapi_vld yuv420p10 1920x1080 >> tonemap_vaapi tonemap_vaapi >> VAAPI vaapi_vld nv12 1920x1080 >> hwdownload hwdownload >> - nv12 nv12 1920x1080 >> format format >> - nv12 nv12 1920x1080 >> format format >> - yuv420p yuv420p 1920x1080 >> overlay overlay >> - yuv420p yuv420p 1920x1080 >> format format >> - nv12 nv12 1920x1080 >> hwupload hwupload >> VAAPI vaapi_vld nv12 1920x1080 >> 03:45:23.555 subtitle_kickoff: call subtitle_resend_current 52 frame->format: 1 03:45:23.829 elapsed=00:00:00.54 frame= 3 fps=0.0 q=0.0 size=N/A time=00:00:00.00 bitrate=N/A throttle=off speed= 0x 03:45:24.474 elapsed=00:00:01.06 frame= 8 fps=7.5 q=-0.0 size=N/A time=00:00:00.25 bitrate=N/A throttle=off speed=0.242x 03:45:24.982 elapsed=00:00:01.57 frame= 12 fps=7.6 q=-0.0 size=N/A time=00:00:00.38 bitrate=N/A throttle=off speed=0.245x 03:45:25.382 elapsed=00:00:02.09 frame= 15 fps=7.1 q=-0.0 size=N/A time=00:00:00.51 bitrate=N/A throttle=off speed=0.245x 03:45:26.025 elapsed=00:00:02.61 frame= 20 fps=7.6 q=-0.0 size=N/A time=00:00:00.73 bitrate=N/A throttle=off speed=0.282x 03:45:26.538 elapsed=00:00:03.12 frame= 24 fps=7.7 q=-0.0 size=N/A time=00:00:00.86 bitrate=N/A throttle=off speed=0.277x 03:45:26.926 elapsed=00:00:03.64 frame= 27 fps=7.4 q=-0.0 size=N/A time=00:00:00.99 bitrate=N/A throttle=off speed=0.273x 03:45:27.577 elapsed=00:00:04.16 frame= 32 fps=7.7 q=-0.0 size=N/A time=00:00:01.25 bitrate=N/A throttle=off speed= 0.3x log 1 >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason VAAPI GeminiLake UHD Graphics 600 - H... >> True True Hardware Codec VideoInput >> True True Same adapter (/dev/dri/renderD128), same hardware co... Scaling >> True True ToneMapping (when possible) >> True True VideoOutput >> True True Hardware encoder VAAPI GeminiLake UHD Graphics 600 - H... >> True True Hardware Codec log 2 PGSSUB CPU >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason VAAPI GeminiLake UHD Graphics 600 - H... >> True True Hardware Codec VideoInput >> True True Same adapter (/dev/dri/renderD128), same hardware co... Scaling >> True True ToneMapping (when possible) >> True True SubtitleOverlay >> False False VideoOutput >> True True Hardware encoder VAAPI GeminiLake UHD Graphics 600 - H... >> True True Hardware Codec
