luser 37 Posted November 29, 2024 Posted November 29, 2024 (edited) Clicking on chapters displays the following error: "Guid should contain 32 digits with 4 dashes" https://i.ibb.co/R7q5TGQ/error.gif Occur on all video files, all containers, all libraries. Occurs on firefox and chrome. *** Error Report *** Version: 4.8.10.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 6.8.0-49-generic (buildd@lcy02-amd64-028) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0, GNU ld (GNU Binutils for Ubuntu) 2. Framework: .NET 6.0.31 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.FormatException: System.FormatException: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). at System.Guid.GuidResult.SetFailure(Boolean overflow, String failureMessageID) at System.Guid.TryParseExactN(ReadOnlySpan`1 guidString, GuidResult& result) at System.Guid.TryParseGuid(ReadOnlySpan`1 guidString, GuidResult& result) at System.Guid..ctor(String g) at MediaBrowser.Controller.Library.LibraryManagerExtensions.GetItemById(ILibraryManager manager, ReadOnlySpan`1 id) at Emby.Api.UserLibrary.UserLibraryService.Get(GetItem request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void SetFailure(Boolean, System.String) --- Sidenote: I don't want chapters. However, Emby forces chapter extraction if "Video Preview Thumbnails" is enabled. You can't have one without the other... These are two different things. In Jellyfin you can disable one or the other, or keep both enabled. For some reason, Emby doesn't allow that... https://i.ibb.co/q7qPsT9/jellyfin-disable-chapters.png Edited November 29, 2024 by luser
luser 37 Posted November 29, 2024 Author Posted November 29, 2024 Upon clicking on a chapter #, a GET request is sent to `https://hostname/emby/Users/<user_id>/Items/chapter_XXXXXX_XXXXXXXXXXX`. It fails with 500 - Internal Server Error
Luke 42243 Posted November 29, 2024 Posted November 29, 2024 Hi there, please attach the complete emby server log file. Thanks.
Malmoth 0 Posted May 8, 2025 Posted May 8, 2025 I can reproduce the issue. I think the stack trace should be enough, right? For context, the exception happens not when we click on the thumbnail for the chapter. That works just fine. It happens when we click on the chapter name. 2025-05-08 15:59:17.662 Error Server: Error processing request *** Error Report *** Version: 4.8.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.12.15-production+truenas (root@tnsbuilds01.tn.ixsystems.net) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 8 Data path: /config Application path: /system System.FormatException: System.FormatException: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). at System.Guid.GuidResult.SetFailure(Boolean overflow, String failureMessageID) at System.Guid.TryParseExactN(ReadOnlySpan`1 guidString, GuidResult& result) at System.Guid.TryParseGuid(ReadOnlySpan`1 guidString, GuidResult& result) at System.Guid..ctor(String g) at MediaBrowser.Controller.Library.LibraryManagerExtensions.GetItemById(ILibraryManager manager, ReadOnlySpan`1 id) at Emby.Api.UserLibrary.UserLibraryService.Get(GetItem request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void SetFailure(Boolean, System.String)
Malmoth 0 Posted May 8, 2025 Posted May 8, 2025 31 minutes ago, Malmoth said: I can reproduce the issue. I think the stack trace should be enough, right? For context, the exception happens not when we click on the thumbnail for the chapter. That works just fine. It happens when we click on the chapter name. 2025-05-08 15:59:17.662 Error Server: Error processing request *** Error Report *** Version: 4.8.11.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.12.15-production+truenas (root@tnsbuilds01.tn.ixsystems.net) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 Framework: .NET 6.0.36 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 8 Data path: /config Application path: /system System.FormatException: System.FormatException: Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). at System.Guid.GuidResult.SetFailure(Boolean overflow, String failureMessageID) at System.Guid.TryParseExactN(ReadOnlySpan`1 guidString, GuidResult& result) at System.Guid.TryParseGuid(ReadOnlySpan`1 guidString, GuidResult& result) at System.Guid..ctor(String g) at MediaBrowser.Controller.Library.LibraryManagerExtensions.GetItemById(ILibraryManager manager, ReadOnlySpan`1 id) at Emby.Api.UserLibrary.UserLibraryService.Get(GetItem request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Private.CoreLib TargetSite: Void SetFailure(Boolean, System.String) To be clear, the corresponding response that contains the request information is like this: 2025-05-08 15:59:17.662 Info Server: http/1.1 Response 500 to host1. Time: 1ms. GET http://host2:9999/emby/Users/1da591a860a74632bcf65363f37109be/Items/chapter_12345_50000000?fields=ShareLevel&ExcludeFields=VideoChapters,VideoMediaSources,MediaStreams&X-Emby-Client=Emby Web&X-Emby-Device-Name=Chrome Windows&X-Emby-Device-Id=564893dd-f6cb-4726-b053-86ec8ac5c74d&X-Emby-Client-Version=4.8.11.0&X-Emby-Token=x_secret3_x&X-Emby-Language=en-gb
