chrisrobbins1970 82 Posted November 28, 2024 Posted November 28, 2024 Is it possible to use two different external domain names?
Neminem 1623 Posted November 28, 2024 Posted November 28, 2024 You could try pointing them to the same IP.
chrisrobbins1970 82 Posted November 28, 2024 Author Posted November 28, 2024 I have two ddns.net domains.. I have one that i've been using for a while, but wanted to know if possible to use another ddns.net domain and separate using a COMMA. Have sometime on my hands and thought I'd try some experimenting
Neminem 1623 Posted November 28, 2024 Posted November 28, 2024 (edited) Ohh ok, you could try, not sure if it will work. Always used a reverse proxy for something like that. I think in that case you should use a reverse proxy, where both domains point to your external ip. And have your revers proxy do the redirecting to your server. Edited November 28, 2024 by Neminem
chrisrobbins1970 82 Posted November 28, 2024 Author Posted November 28, 2024 never used a reverse proxy before
chrisrobbins1970 82 Posted November 28, 2024 Author Posted November 28, 2024 well holy smoke..i really didn't think it would work but.....i was able to add to separate ddns.net domain address for remote login... http://servername.ddns.net,http://servername2.ddns.net and it worked..DID not think it would work but it did....
