Changing genres and tags with API
Go to solution Solved by Killface69,
Killface69
I'm trying to update Emby genres and tags with the API in python.
Please see below the code in question.
I tried setting only all the genres/tags at a time with no succuees, I also tried "GenreItems" and "TagItems" instead.
I also converted the list to string items with ', ' and '; ' as separators.
I was able to actually get updated genres for my library items yesterday, but I have no clue what I was doing different.
Do I need to use the TagService for the tags, including Name and Id?
EDIT: Maybe I'm missing this? https://betadev.emby.media/reference/RestAPI/ItemUpdateService/postItemsByItemid.html
Quote
postItemsByItemid
Requires authentication as administrator
                print(f"\r{filter_tdb_new_genres}")
  				['ᵃᵈᵛ Adventure', 'ᵃᶜᵗ Action', 'ᶜʳⁱ Crime']
                print(f"\r{tdb_new_tags}")
      			[' TMDB 1. Top', ' MEGA Blockbuster', ' Hollywood Film', ' Big Budget Film', ' Academy Award - Winner', ' Academy Award - Nomination', ' Golden Globe - Nomination']
                emby_server.set_genres_and_tags(media_item.emby_item_id, filter_tdb_new_genres, tdb_new_tags)
    def set_genres_and_tags(self, item_id, genres: list, tags: list):
        return self.update_item(item_id, {
            "Genres": genres,
            "Tags": tags})
    def get_item(self, item_id) -> dict:
        endpoint = f"/emby/users/{self.emby_user_id}/items/{item_id}"
        url = self.emby_server_url + endpoint
        try:
            response = requests.get(url, headers=self.headers)
            response.raise_for_status()
            return response.json()
        except requests.RequestException as e:
            print(f"Error while getting item {item_id}: {e}")
            return None
        def update_item(self, item_id, updates: dict, max_retries: int = 3, base_delay: float = 0.1,
                    max_delay: float = 2.0) -> bool:
        item = self.get_item(item_id)
        if not item:
            tqdm.write(f"\rItem {item_id} not found.")
            return False
        # Update LockedFields if needed
        if "ForcedSortName" in updates and "SortName" not in item.get("LockedFields", []):
            item.setdefault("LockedFields", []).append("SortName")
        # print(item)
        # Combine updates
        item.update(updates)
        # print(updates)
        # print(item)
        update_url = f"{self.emby_server_url}/emby/Items/{item_id}?api_key={self.api_key}"
        delay = base_delay
        for attempt in range(1, max_retries + 1):
            try:
                response = requests.post(update_url, json=item, headers=self.headers)
                response.raise_for_status()  # Raise error for non-2xx responses
                # print(response.text)
                tqdm.write(f"\rUpdated item {item_id} with {updates}.")
                time.sleep(self.seconds_between_requests)
                return True
                tqdm.write(f"\rError while updating item {item_id} (Attempt {attempt}/{max_retries}): {e}")
                if attempt < max_retries:
                    time.sleep(delay)
                    delay = min(delay * 5, max_delay)  # Erhöhe das Delay exponentiell
                else:
                    tqdm.write(f"\rFailed to update item {item_id} after {max_retries} attempts.")
                    return False
Edited by Killface69
  • Solution
Killface69
Found a solution, it's only working if both xyz and xyzItems are updated at once.
Working example:
            "Genres": genres,
            "GenreItems": genres,
            "Tags": tags,
            "TagItems": tags,
  • Thanks 1
