Luke 42241 Posted November 26, 2024 Posted November 26, 2024 Hi, did you try the process listed in that topic?
mike3821 67 Posted November 26, 2024 Author Posted November 26, 2024 I went to LIVe TV / Recordings and their is no plus symbol to add a recording
Luke 42241 Posted November 27, 2024 Posted November 27, 2024 1 hour ago, mike3821 said: I went to LIVe TV / Recordings and their is no plus symbol to add a recording Hi, what Emby app are you trying to do this with?
mike3821 67 Posted November 27, 2024 Author Posted November 27, 2024 30 minutes ago, Luke said: Hi, what Emby app are you trying to do this with? Iphone
mike3821 67 Posted November 27, 2024 Author Posted November 27, 2024 1 hour ago, Luke said: Hi, what Emby app are you trying to do this with? Found it by using my computer. Is there anyway to tell it to create only new movies in hallmark with this function?
Luke 42241 Posted November 27, 2024 Posted November 27, 2024 3 hours ago, mike3821 said: Found it by using my computer. Is there anyway to tell it to create only new movies in hallmark with this function? You mean with hallmark in the title?
mike3821 67 Posted November 27, 2024 Author Posted November 27, 2024 5 hours ago, Luke said: You mean with hallmark in the title? Not sure if tha'ts how you would do it. That's why I'm asking. I want to record every new Christmas Movie on the Hallmark channel. Is there a way?
Luke 42241 Posted November 27, 2024 Posted November 27, 2024 6 hours ago, mike3821 said: Not sure if tha'ts how you would do it. That's why I'm asking. I want to record every new Christmas Movie on the Hallmark channel. Is there a way? How would the server determine that?
Carlo 4561 Posted November 30, 2024 Posted November 30, 2024 Setup a keyword search for Hallmark Channel searching Title for "Christmas" Same as above but for "Holiday" Setup a keyword search for Hallmark Channel searching Overview for "Christmas" Same as above but for "Holiday" Set them to record all episodes You'll see this: Unclick that option, then enable it again. Enable the check for existing episodes in all libraries @LukeIs that intentional above to not show the 2nd option be default or bug?
mike3821 67 Posted November 30, 2024 Author Posted November 30, 2024 5 hours ago, Carlo said: Setup a keyword search for Hallmark Channel searching Title for "Christmas" Same as above but for "Holiday" Setup a keyword search for Hallmark Channel searching Overview for "Christmas" Same as above but for "Holiday" Set them to record all episodes You'll see this: Unclick that option, then enable it again. Enable the check for existing episodes in all libraries @LukeIs that intentional above to not show the 2nd option be default or bug? This will record all movies. I want to record just the new ones for 2024.
Carlo 4561 Posted November 30, 2024 Posted November 30, 2024 No. You would have to check the scheduled recordings and remove any that you don't want to record.
