godfuture 5 Posted November 24, 2024 Posted November 24, 2024 The web player has no option to add the currently playing item to favorites or to playlists. I guess many users here in the forum will answer now that I can do this within the library. Thats right. But when I play an item from the movies overview or from a list directly then going back from web player means to return to originate location, not the media that was played. If you do not exactly remember which media you played, you have to look again for the needle in a haystack. Therefore I suggest to do the following: Preferred: add options for favorites and playlists to web player. or Make sure that the web player always returns the user to the item last played (this is not preferred, because when you are playing from a playlist, and you want to "like" an item, you would have to exit the web player to toggle favorites and come back to your playlist).
ebr 16337 Posted November 25, 2024 Posted November 25, 2024 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at:
