Neminem 1630 Posted November 28, 2024 Posted November 28, 2024 1 minute ago, rbjtech said: ie a receipe for db corruption. Ha ha yes, logs are full of SQL errors Ohh well mine is just a toss away test db. Â 2024-11-28 17:09:27.915 Error BaseItem: Error refreshing item Desire Is All You Need 285984 /media/Series 4K/Yellowstone (2018)/Yellowstone (2018) - S05E09 - Desire Is All You Need - [ WEBDL-2160p ][ 8-bit h265 ][ EAC3 5.1 ].disc *** Error Report *** Version: 4.9.0.32 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 6.6.56-Unraid (root@Develop) (gcc (GCC) 14.2.0, GNU ld version 2.43.1-slack151) #1 SMP PREEMPT_DYNAMIC Thu Oct 10 21:34:15 PDT 2024 OS/Process: x64/x64 Framework: .NET 8.0.10 Runtime: system/System.Private.CoreLib.dll Processor count: 8 Data path: /config Application path: /system SQLitePCL.pretty.SQLiteException: Constraint: FOREIGN KEY constraint failed SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at SQLitePCL.pretty.DatabaseConnection.Execute(IDatabaseConnection This, String sql) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItemsInTranscation(IDatabaseConnection db, List`1 items, MetadataRefreshOptions metadataRefreshOptions) at Emby.Server.Implementations.Data.SqliteItemRepository.SaveItems(List`1 items, MetadataRefreshOptions metadataRefreshOptions, Action`1 afterSave, Boolean disableForeignKeys, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.LibraryManager.UpdateItems(List`1 items, BaseItem parent, ItemUpdateType updateReason, Boolean setDateLastSaved, Boolean saveMetadata, MetadataRefreshOptions metadataRefreshOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.SaveItem(MetadataResult`1 result, Boolean isFirstRefresh, LibraryOptions libraryOptions, ItemUpdateType reason, IDirectoryService directoryService, MetadataRefreshOptions metadataRefreshOptions, CancellationToken cancellationToken) at Emby.Providers.Manager.MetadataService`2.RefreshMetadata(BaseItem item, MetadataRefreshOptions refreshOptions, BaseItem[] collectionFolders, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadata(MetadataRefreshOptions options, BaseItem[] collectionFolders, LibraryOptions libraryOptions, CancellationToken cancellationToken) at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadataRecursive(BaseItem[] children, MetadataRefreshOptions refreshOptions, BaseItem[] collectionFolders, LibraryOptions libraryOptions, Boolean recursive, Dictionary`2 newItemIds, IProgress`1 progress, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: Void CheckOk(SQLitePCLEx.sqlite3, Int32) Â 1
pmac 143 Posted November 28, 2024 Author Posted November 28, 2024 Okay, so removing my 4K library allows the series to merge. Thanks guys. I was hoping I'd be able to have a separate 4k television library like I do with 4k movies (just for easier access when using a 4k capable tv), but this is better than nothing 2
