fc7 123 Posted December 3, 2015 Posted December 3, 2015 Hello, please help how to fix this problem on centos 6 64bit server: Error: Package: libmediainfo-0.7.76-1.el6.x86_64 (@epel) Requires: libtinyxml2.so.1()(64bit) Removing: tinyxml2-1.0.11-4.20130805git0323851.el6.x86_64 (@epel) libtinyxml2.so.1()(64bit) Updated By: tinyxml2-2.1.0-5.1.x86_64 (home_emby) Not found You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest Thanks for reporting this issue. This problem should be solved now. Please notice that you may need to run "yum clean all" to clear all yum cached data before trying to update the system again or you may keep getting the error.
mickr 1 Posted December 4, 2015 Posted December 4, 2015 I'm not sure in which forum to address this issue: My wife has lost about 95% of her sight since March this year. I am attempting to use Emby and Roku so she may listen to books in MP3 format. I noticed there is no guidence with respect to setting up a book library - I have attempted to use 'music' without success: There are problems with adding a CentOS 6 mounted /media/bookdiskname to the Emby library (visible, but resets entry whenever 'added' - I can get as far as /media - and that's it). So access to the /media/diskname/book/chapter1.mp3, chapter2.mp3, ... chaptern.mp3 is naturally a problem. Any suggestions?
fc7 123 Posted December 4, 2015 Posted December 4, 2015 Sorry to hear that about your wife. Maybe you want to post this into the general Linux forum so more people see it and may help you with this. I'm not using audio books or books libraries so I can't really help. Sent from my iPhone using Tapatalk
mickr 1 Posted December 4, 2015 Posted December 4, 2015 What is the character? It may be that our web entry form isn't handling it properly. Especially if it is something like a percent sign (%). My apologies for the delay. It's a bang. No problems with manually logging into the erver.
Johnny5 0 Posted December 14, 2015 Posted December 14, 2015 I get the following errors when trying to install emby-server via yum following the instructions on the download page (CentOS 7 64b); $ sudo yum install emby-server . . . --> Finished Dependency Resolution Error: Package: ImageMagick-libs-6.9.1-29.1.x86_64 (home_emby) Requires: libIlmImf.so.6()(64bit) Error: Package: ImageMagick-libs-6.9.1-29.1.x86_64 (home_emby) Requires: libgs.so.8()(64bit) Error: Package: ImageMagick-libs-6.9.1-29.1.x86_64 (home_emby) Requires: libwebp.so.5()(64bit) You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest This is a fresh CentOS install with yum updates.
fc7 123 Posted December 14, 2015 Posted December 14, 2015 Did you add EPEL repo to your system? Is mandatory. Sent from my iPhone using Tapatalk
Johnny5 0 Posted December 14, 2015 Posted December 14, 2015 Did you add EPEL repo to your system? Is mandatory. Yes the EPEL repo has been added; $ cat /etc/yum.repos.d/epel.repo [epel] name=Extra Packages for Enterprise Linux 7 - $basearch #baseurl=http://download.fedoraproject.org/pub/epel/7/$basearch mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-7&arch=$basearch failovermethod=priority enabled=1 gpgcheck=1 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7 [epel-debuginfo] name=Extra Packages for Enterprise Linux 7 - $basearch - Debug #baseurl=http://download.fedoraproject.org/pub/epel/7/$basearch/debug mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-debug-7&arch=$basearch failovermethod=priority enabled=0 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7 gpgcheck=1 [epel-source] name=Extra Packages for Enterprise Linux 7 - $basearch - Source #baseurl=http://download.fedoraproject.org/pub/epel/7/SRPMS mirrorlist=https://mirrors.fedoraproject.org/metalink?repo=epel-source-7&arch=$basearch failovermethod=priority enabled=0 gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-EPEL-7 gpgcheck=1
fc7 123 Posted December 15, 2015 Posted December 15, 2015 (edited) Can you run 'yum clean all' and then 'yum install emby-server'? Please post both commands complete output not just the last few lines. ThanksSent from my iPhone using Tapatalk Edited December 15, 2015 by fc7
fc7 123 Posted December 15, 2015 Posted December 15, 2015 Just for the record I tried to install emby-server on a fresh CentOS 7.1 (minimal) install and also on a CentOS 7.2 (minimal) install updated from 7.1. In both cases I didn't face any issues with the installation, nor with the package dependancies. All the packages should come from Base, Update and EPEL. Only exceptions are: sqlite, mono and ImageMagick, that should be retrieved from Emby repo. It just works. Once you share the output of the commands I requested before, I will check it to try to find whats going on.
Johnny5 0 Posted December 16, 2015 Posted December 16, 2015 I don't know why but yesterday I tried to re-run "yum install emby-server" and it worked. I have no idea why it started working, thanks though.
fc7 123 Posted December 16, 2015 Posted December 16, 2015 I don't know why but yesterday I tried to re-run "yum install emby-server" and it worked. I have no idea why it started working, thanks though. Good to hear that. A few changes are coming with the new beta including a big one. We will not require ImageMagick anymore, we will provide the needed libraries in a separate package that will not conflict with any distro stock ImageMagick package.
fc7 123 Posted December 21, 2015 Posted December 21, 2015 With the new stable release version of Emby, 3.0.5781.8, new packages with several important changes are available for Fedora/CentOS. Including: We created a new package called embymagick that provides the needed libraries from ImageMagick to run Emby . This package can be installed side-by-side with the stock ImageMagick included with all the distros so there should be no more conflicts. It's highly recommended that you uninstall the previous ImageMagick packages provided by us, and if needed, just install the stock ones included with the distro. Ahead Of Time (AOT) code is included in the new package, hoping to increase performance by executing precompiled code instead of JIT. The old, empty, emby-server.conf under /etc now includes some guidelines in case you need to override the defaults. In previous versions, only the runas user (emby by default) was able to restart Emby when you pressed the restart button in the UI. Starting with this version, any user in emby group will be able to do so. If you change the default runas user, we will try to automatically add the new one to the emby group. Hope you enjoy it and as always, any feedback is welcome.
Doonga 17 Posted December 22, 2015 Posted December 22, 2015 (edited) I think you have a typo in emby-server.sh It currently reads as: exec su -s /bin/sh -c 'exec "$0" "$@"' $USER -- \ env $MONO_EXEC_ENV $MONO_EXEC $MONO_EXEC_OPTS $EMBY_EXEC $EMBY_OPTS > $LOG_FILE 2>&1 But I get this in /var/log/emby-server.log su: user env does not exist I had a feeling that's because $USER was blank (which that is indeed the case.) So I changed the line to: exec su -s /bin/sh -c 'exec "$0" "$@"' $EMBY_USER -- \ env $MONO_EXEC_ENV $MONO_EXEC $MONO_EXEC_OPTS $EMBY_EXEC $EMBY_OPTS > $LOG_FILE 2>&1 Now it starts ok. Probably should be corrected though. note: It works OK if you run emby-server.sh from the command line, but it explodes when run via systemctl. Edited December 22, 2015 by Doonga
fc7 123 Posted December 22, 2015 Posted December 22, 2015 I will look into it ASAP. Sent from my iPhone using Tapatalk
fc7 123 Posted December 22, 2015 Posted December 22, 2015 (edited) I think you have a typo in emby-server.sh It currently reads as: exec su -s /bin/sh -c 'exec "$0" "$@"' $USER -- \ env $MONO_EXEC_ENV $MONO_EXEC $MONO_EXEC_OPTS $EMBY_EXEC $EMBY_OPTS > $LOG_FILE 2>&1 But I get this in /var/log/emby-server.log su: user env does not exist I had a feeling that's because $USER was blank (which that is indeed the case.) So I changed the line to: exec su -s /bin/sh -c 'exec "$0" "$@"' $EMBY_USER -- \ env $MONO_EXEC_ENV $MONO_EXEC $MONO_EXEC_OPTS $EMBY_EXEC $EMBY_OPTS > $LOG_FILE 2>&1 Now it starts ok. Probably should be corrected though. note: It works OK if you run emby-server.sh from the command line, but it explodes when run via systemctl. A new package revision is out that should fix this problem. Please try it out and let me know if it works for you (yum update emby-server). Thanks. Edited December 22, 2015 by fc7
Doonga 17 Posted December 22, 2015 Posted December 22, 2015 A new package revision is out that should fix this problem. Please try it out and let me know if it works for you (yum update emby-server). Thanks. Much better now! Thanks!
fc7 123 Posted December 28, 2015 Posted December 28, 2015 With the new Emby stable release 3.0.5782.0, also mono was updated from 4.0.3 to 4.2.1 for CentOS/Fedora (we are just replicating the Xamarin release, no modifications). This change will bring support for IPv6 and many other improvements on the mono side. As always any feedback will be welcome. Enjoy 1
Adamizme 3 Posted December 31, 2015 Posted December 31, 2015 I created an account just to come on here and thank whoever for creating embymagick and resolving the dependency issues. I am finally able to run Emby on my CentOS 7 box. Thank you! 3
Sparx7 0 Posted January 14, 2016 Posted January 14, 2016 Hello, I would like to try emby on my VPS running CentOS 6.6 I get the following error when I try to install it: Error: Package: emby-server-3.0.5607.2-Stable.21.1.noarch (home_jose-pr_Emby) Requires: sqlite >= 3.8.2 Installed: sqlite-3.6.20-1.el6_7.2.i686 (@updates) sqlite = 3.6.20-1.el6_7.2 Available: sqlite-3.6.20-1.el6.i686 (base) sqlite = 3.6.20-1.el6 Apparently there is no newer sqlite version available for me.Any idea how i can fix this? Thanks in advance
fc7 123 Posted January 14, 2016 Posted January 14, 2016 (edited) Hello, I would like to try emby on my VPS running CentOS 6.6 I get the following error when I try to install it: Apparently there is no newer sqlite version available for me. Any idea how i can fix this? Thanks in advance Please read and follow the installation instructions in Emby website: https://emby.media/downloads/linux-server/ Edited January 14, 2016 by fc7 1
Sparx7 0 Posted January 14, 2016 Posted January 14, 2016 I feel so stupid now. I followed the instructions but accidentally used the CentOS 7 Repo
fc7 123 Posted January 14, 2016 Posted January 14, 2016 I feel so stupid now. I followed the instructions but accidentally used the CentOS 7 Repo No worries. Enjoy Emby!
harisund 2 Posted March 18, 2016 Posted March 18, 2016 hey, I didn't realize there was this thread. I just created a new post here - http://emby.media/community/index.php?/topic/32805-centos7-systemd-script-broken/ Any thoughts on perhaps how I can submit a patch?
dcrdev 255 Posted April 19, 2016 Posted April 19, 2016 As of today the Fedora 23 repo is reporting a new update, but the rpm doesn't exist on the origin server?
