le.kiwi 0 Posted September 9, 2015 Posted September 9, 2015 Hey there, first of all a big thanks and well done to everybody involved with Emby. In my opinion, among the best things, that ever happened to the HTPC world. The other reason I am writing here is the CentOS/Fedora Package. Emby is runnig under a different user and group on my server, and as advised in the /etc/default/emby-server.conf, I made my changes to /etc/emby-server.conf. Now with every update, of the 3.0.5724 package this file (/etc/emby-server.conf) got reset to blank. Is my setup to blame or did isn't this working as intended? Thanks again
rtterry 1 Posted September 14, 2015 Posted September 14, 2015 (edited) My issue is when I install the new version I am told I don't have permission to run the script. Top it when I run 'yum update' it tries to update files using by the installation that clearly are older version at install. Dependencies Resolved========================================================================================================================================== Package Arch Version Repository Size==========================================================================================================================================Installing: emby-server noarch 3.0.5724.4-261.1 home_emby 14 MInstalling for dependencies: ImageMagick x86_64 6.9.1-13.3 home_emby 131 k ImageMagick-libs x86_64 6.9.1-13.3 home_emby 2.0 M libgdiplus0 x86_64 3.12-9.1 home_emby 149 k libmediainfo x86_64 0.7.76-1.el6 epel 2.0 M mono-core x86_64 4.0.3.20-3.1 home_emby 16 M mono-data x86_64 4.0.3.20-3.1 home_emby 3.5 M mono-data-sqlite x86_64 4.0.3.20-3.1 home_emby 68 k mono-extras x86_64 4.0.3.20-3.1 home_emby 435 k mono-mvc x86_64 4.0.3.20-3.1 home_emby 458 k mono-wcf x86_64 4.0.3.20-3.1 home_emby 870 k mono-web x86_64 4.0.3.20-3.1 home_emby 2.0 M mono-winforms x86_64 4.0.3.20-3.1 home_emby 1.5 M mono-winfxcore x86_64 4.0.3.20-3.1 home_emby 275 k tinyxml2 x86_64 1.0.11-4.20130805git0323851.el6 epel 31 kTransaction Summary==========================================================================================================================================Install 15 Package(s)Total download size: 43 MInstalled size: 156 M Speciffically, ' tinyxml2' and 'libmediainfo' are not the most current versions. Did I mention that it is not installing the latest version of emby either. Clearly, stated in a recent post this version should be "emby server v3.0.5724.3-219.1". There are unfinished transactions remaining. You might consider running yum-complete-transaction first to finish them.--> Running transaction check---> Package tinyxml2.x86_64 0:1.0.11-4.20130805git0323851.el6 will be updated--> Processing Dependency: libtinyxml2.so.1()(64bit) for package: libmediainfo-0.7.76-1.el6.x86_64---> Package tinyxml2.x86_64 0:2.1.0-5.1 will be an update--> Finished Dependency ResolutionError: Package: libmediainfo-0.7.76-1.el6.x86_64 (@epel) Requires: libtinyxml2.so.1()(64bit) Removing: tinyxml2-1.0.11-4.20130805git0323851.el6.x86_64 (@epel) libtinyxml2.so.1()(64bit) Updated By: tinyxml2-2.1.0-5.1.x86_64 (home_emby) Not found You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest Now I complete removed my old version of emby and all emby files and dependancies. I still get these errors on my server on a fresh install of emby. I have no clue how to resolve this issue. I am running CentOS 6 on my host. Edited September 14, 2015 by rtterry
rtterry 1 Posted September 14, 2015 Posted September 14, 2015 (edited) I tried to install the new version of emby after I manually update the outdated files but It didnt work. This version of emby is using out dated files and if not able to run properly on version of CentOS that are fully updated to current versons of the dependant software. This conflict is versions will make it hard for many people like me to run the new version of the script. Does anyone know of a work around for this issue or do the developers plan to release an update that can actually use all current version and allow for directly download of the current release since the respository is push an out dated version for CentOS 6. I am running on a 64bit version of CentOS so I can not use the 686i version of the dependancies. [root@tmyhost ~]# yum install libmediainfoLoaded plugins: fastestmirrorSetting up Install ProcessLoading mirror speeds from cached hostfile * base: mirrors.advancedhosters.com * epel: mirror.cogentco.com * extras: repo.dimenoc.com * livna: rpm.livna.org * rpmforge: mirror.teklinks.com * updates: mirror.ash.fastserv.com * webtatic: us-east.repo.webtatic.comResolving DependenciesThere are unfinished transactions remaining. You might consider running yum-complete-transaction first to finish them.--> Running transaction check---> Package libmediainfo.x86_64 0:0.7.76-1.el6 will be installed--> Processing Dependency: libtinyxml2.so.1()(64bit) for package: libmediainfo-0.7.76-1.el6.x86_64--> Finished Dependency ResolutionError: Package: libmediainfo-0.7.76-1.el6.x86_64 (epel) Requires: libtinyxml2.so.1()(64bit) Available: tinyxml2-1.0.11-4.20130805git0323851.el6.x86_64 (epel) libtinyxml2.so.1()(64bit) Installed: tinyxml2-2.1.0-5.1.x86_64 (@home_emby) Not found You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest Installed PackagesName : tinyxml2Arch : x86_64Version : 2.1.0Release : 5.1Size : 88 kRepo : installedFrom repo : home_embySummary : Simple, small and efficient C++ XML parserURL : https://github.com/leethomason/tinyxml2License : zlibDescription : TinyXML-2 is a simple, small, efficient, C++ XML parser that can be : easily integrated into other programs. It uses a Document Object Model : (DOM), meaning the XML data is parsed into a C++ objects that can be : browsed and manipulated, and then written to disk or another output stream. : : TinyXML-2 doesn't parse or use DTDs (Document Type Definitions) nor XSLs : (eXtensible Stylesheet Language). : : TinyXML-2 uses a similar API to TinyXML-1, But the implementation of the : parser was completely re-written to make it more appropriate for use in a : game. It uses less memory, is faster, and uses far fewer memory allocations.Available PackagesName : libmediainfoArch : i686Version : 0.7.76Release : 1.el6Size : 2.1 MRepo : epelSummary : Library for supplies technical and tag information about a video or audio fileURL : http://mediaarea.net/MediaInfoLicense : BSDDescription : This package contains the shared library for MediaInfo. : MediaInfo supplies technical and tag information about a video or : audio file. : : What information can I get from MediaInfo? : * General: title, author, director, album, track number, date, duration... : * Video: codec, aspect, fps, bitrate... : * Audio: codec, sample rate, channels, language, bitrate... : * Text: language of subtitle : * Chapters: number of chapters, list of chapters : : DivX, XviD, H263, H.263, H264, x264, ASP, AVC, iTunes, MPEG-1, : MPEG1, MPEG-2, MPEG2, MPEG-4, MPEG4, MP4, M4A, M4V, QuickTime, : RealVideo, RealAudio, RA, RM, MSMPEG4v1, MSMPEG4v2, MSMPEG4v3, : VOB, DVD, WMA, VMW, ASF, 3GP, 3GPP, 3GP2 : : What format (container) does MediaInfo support? : * Video: MKV, OGM, AVI, DivX, WMV, QuickTime, Real, MPEG-1, : MPEG-2, MPEG-4, DVD (VOB) (Codecs: DivX, XviD, MSMPEG4, ASP, : H.264, AVC...) : * Audio: OGG, MP3, WAV, RA, AC3, DTS, AAC, M4A, AU, AIFF : * Subtitles: SRT, SSA, ASS, SAMIName : libmediainfoArch : x86_64Version : 0.7.76Release : 1.el6Size : 2.0 MRepo : epelSummary : Library for supplies technical and tag information about a video or audio fileURL : http://mediaarea.net/MediaInfoLicense : BSDDescription : This package contains the shared library for MediaInfo. : MediaInfo supplies technical and tag information about a video or : audio file. : : What information can I get from MediaInfo? : * General: title, author, director, album, track number, date, duration... : * Video: codec, aspect, fps, bitrate... : * Audio: codec, sample rate, channels, language, bitrate... : * Text: language of subtitle : * Chapters: number of chapters, list of chapters : : DivX, XviD, H263, H.263, H264, x264, ASP, AVC, iTunes, MPEG-1, : MPEG1, MPEG-2, MPEG2, MPEG-4, MPEG4, MP4, M4A, M4V, QuickTime, : RealVideo, RealAudio, RA, RM, MSMPEG4v1, MSMPEG4v2, MSMPEG4v3, : VOB, DVD, WMA, VMW, ASF, 3GP, 3GPP, 3GP2 : : What format (container) does MediaInfo support? : * Video: MKV, OGM, AVI, DivX, WMV, QuickTime, Real, MPEG-1, : MPEG-2, MPEG-4, DVD (VOB) (Codecs: DivX, XviD, MSMPEG4, ASP, : H.264, AVC...) : * Audio: OGG, MP3, WAV, RA, AC3, DTS, AAC, M4A, AU, AIFF : * Subtitles: SRT, SSA, ASS, SAMIName : tinyxml2Arch : i686Version : 1.0.11Release : 4.20130805git0323851.el6Size : 32 kRepo : epelSummary : Simple, small and efficient C++ XML parserURL : https://github.com/leethomason/tinyxml2License : zlibDescription : TinyXML-2 is a simple, small, efficient, C++ XML parser that can be : easily integrated into other programs. It uses a Document Object Model : (DOM), meaning the XML data is parsed into a C++ objects that can be : browsed and manipulated, and then written to disk or another output stream. : : TinyXML-2 doesn't parse or use DTDs (Document Type Definitions) nor XSLs : (eXtensible Stylesheet Language). : : TinyXML-2 uses a similar API to TinyXML-1, But the implementation of the : parser was completely re-written to make it more appropriate for use in a : game. It uses less memory, is faster, and uses far fewer memory allocations. Edited September 14, 2015 by rtterry
stangri 2 Posted September 14, 2015 Posted September 14, 2015 Had the same problem a few pages back. Solution is to install priority plugin and assign higher priority to emby repo than epel repo. 1
rtterry 1 Posted September 14, 2015 Posted September 14, 2015 (edited) Had the same problem a few pages back. Solution is to install priority plugin and assign higher priority to emby repo than epel repo. That actually fix my installation and allowed me to install the lastest version of emby on my host using the lastest version of the installed scripts. However, my host says I dont have permission to run the script. So I would think this is an issue with the permission set during the install. [root@myserverinfo ~]# service emby-server start Starting emby-server daemon: emby-server is already running or you don't have enough privileges to start the service. [FAILED] I am positive the emby-server is not already running but I don't know the next step to get it running. Changing the permissions of the file nor ownership from root resolve the issue. Edited September 14, 2015 by rtterry
rtterry 1 Posted September 15, 2015 Posted September 15, 2015 I was able to get the lastest version of emby recently updated via the repo but I am still not able to run server because it is still giving me the permission error. [root@myserverinfo ~]# service emby-server startStarting emby-server daemon: emby-server is already running or you don't have enough privileges to start the service. [FAILED] Does anyone have a solution for this issue?
rtterry 1 Posted September 15, 2015 Posted September 15, 2015 Okay, so I contacted my Dedicated Server tech support about this issue and here is what they did to fix the issue and their description of what caused the issue. Due to some unknown reason the PID file '/var/run/emby-server.pid' wasn't removing when the process is stopped. I believe this has happened due to a corrupted PID file. I had to remove it to fix the issue. I hope this information help someone else that may have a simular issue.
dlhenke 0 Posted September 16, 2015 Posted September 16, 2015 Got it working on fedora 22 .. without epel-release because epel-release does not work on fedora 22wget http://download.opensuse.org/repositories/home:/emby/Fedora_20/home:emby.repo -O /etc/yum.repos.d/emby.repo dnf install emby-server sudo rpm -ivh http://download1.rpmfusion.org/free/fedora/rpmfusion-free-release-stable.noarch.rpmsudo dnf install vlcsudo dnf install gstreamer-plugins-bad gstreamer-plugins-bad-free-extras gstreamer-plugins-ugly gstreamer-ffmpeg gstreamer1-libav gstreamer1-plugins-bad-free-extras gstreamer1-plugins-bad-freeworld gstreamer-plugins-base-tools gstreamer1-plugins-good-extras gstreamer1-plugins-ugly gstreamer1-plugins-bad-free gstreamer1-plugins-good gstreamer1-plugins-base gstreamer1dnf install mono-winfxcore mono-data-sqlite mono-mvc mono-web mono-wcf mono-data mono-winforms mono-extras mono-coreAnd voilasystemctl start emby-server Run Setup Wizard Visit http://localhost:8096
rtterry 1 Posted September 16, 2015 Posted September 16, 2015 Well it seems the permissions issue come back on reboot or re-start after the script has already been ran before. It would seem that something happens while running that corrupts the PID file. [root@myserverinfo ~]# service emby-server startStarting emby-server daemon: emby-server is already running or you don't have enough privileges to start the service. [FAILED]
rtterry 1 Posted September 18, 2015 Posted September 18, 2015 It is very frustrating that this great platform is getting very little support to resolve issues with all the supported OSs. Specifically, CentOS 6.x and because of this I have decided to uninstall the server. I was using it to stream movies to my TV for my daughter and was hurt by the disappointment on her face when after two weeks or so I was not able to fix the streaming device. Sadly, I had to move to a differen platform and I wonder how I would have felt if I had paid for the premiumn access and gotten the same poor support. This new platform was a little tricky to install but very well documented and was very easy to install. The updates are done from the dashboard and works very simular to Emby after the initial setup. Sorry, Emby community but I have to move on to greener plains.
Luke 42242 Posted September 18, 2015 Author Posted September 18, 2015 It is very frustrating that this great platform is getting very little support to resolve issues with all the supported OSs. Specifically, CentOS 6.x and because of this I have decided to uninstall the server. I was using it to stream movies to my TV for my daughter and was hurt by the disappointment on her face when after two weeks or so I was not able to fix the streaming device. I apologize and I see the issues you've reported. If you look around the forum you can see we're generally extremely helpful. You started reporting your issues 4 days ago on the 13th. I realize that seems like a long time to you but sometimes there are tricky issues that do take a little time to resolve, and we often discuss privately about what needs to be changed in order to resolve it. It probably would have helped if we had at least followed up with you just so that you see that we're looking into it.
rtterry 1 Posted September 18, 2015 Posted September 18, 2015 I apologize and I see the issues you've reported. If you look around the forum you can see we're generally extremely helpful. You started reporting your issues 4 days ago on the 13th. I realize that seems like a long time to you but sometimes there are tricky issues that do take a little time to resolve, and we often discuss privately about what needs to be changed in order to resolve it. It probably would have helped if we had at least followed up with you just so that you see that we're looking into it. Communication is a major part of my reason for migrating. I do a lot of dedicated server work and web development. It is a major peice in the equation that I communicate with my users and clients. So they know I am dedicated to providing them quality service. As I mention it did not make it any better that I have a seven year old daughter asking everyday multiple times have I fixed it yet. I spent hours searching site and web for a solution. So yes it seem like four years! She will be happy in the AM that she can watch Big 6 and Frozen another 20 times on the big Screen. While I have the peace of knowing she is watch kid safe programing. I hope you workout the kinks in your new release and contiue to build on your system. Though, I lost some features on the new product, unless I pay for them it works and that is all that was important to me. Unlike Emby it the new version of the Roku app was not compatiable with my SD TV so I had to load a Classic version but that was simple enough. I will note that another issue I ran into when I did have the host running was that my Roku 2 would connect to the host. Then load all my movies from the library but when I tried to play a video from the TV streaming device it was close the playback and revert back to the play movie menu. I figured that was cause it needed to be updated to work with the current version of the Emby app but it just wasnt working. I could playback from the computer and mobile browser with no issue.
fc7 123 Posted September 21, 2015 Posted September 21, 2015 Hey there, first of all a big thanks and well done to everybody involved with Emby. In my opinion, among the best things, that ever happened to the HTPC world. The other reason I am writing here is the CentOS/Fedora Package. Emby is runnig under a different user and group on my server, and as advised in the /etc/default/emby-server.conf, I made my changes to /etc/emby-server.conf. Now with every update, of the 3.0.5724 package this file (/etc/emby-server.conf) got reset to blank. Is my setup to blame or did isn't this working as intended? Thanks again It's not a setup problem, but a packaging issue that I will fix as soon as possible. Thanks for reporting this problem.
fc7 123 Posted September 21, 2015 Posted September 21, 2015 Well it seems the permissions issue come back on reboot or re-start after the script has already been ran before. It would seem that something happens while running that corrupts the PID file. Did you check if the pid file existed when you tried to start the service? If there is a pid file the service will not start since it will assume that Emby is already running. I will review the script to see if there is anything that I missed.
fc7 123 Posted September 21, 2015 Posted September 21, 2015 It's not a setup problem, but a packaging issue that I will fix as soon as possible. Thanks for reporting this problem. @le.kiwi. I just fix the packages so the problem should be solved from now on. Next upgrade shouldn't overwrite your config file. 1
le.kiwi 0 Posted September 25, 2015 Posted September 25, 2015 @le.kiwi. I just fix the packages so the problem should be solved from now on. Next upgrade shouldn't overwrite your config file. Thank you very much. Worked like a charm.
fc7 123 Posted October 13, 2015 Posted October 13, 2015 After a couple of users reported "Out of Memory" problems with current CentOS packages, we decided to reduce the default mono nursery size from 512MB to 128MB. This change is already applied in emby-server-dev and it will be included in the next beta and stable releases. Just as a reminder, you can override the default configuration by defining new values in /etc/emby-server.conf that is empty by default. Cheers.
fc7 123 Posted October 20, 2015 Posted October 20, 2015 After a couple of users reported "Out of Memory" problems with current CentOS packages, we decided to reduce the default mono nursery size from 512MB to 128MB. This change is already applied in emby-server-dev and it will be included in the next beta and stable releases. Just as a reminder, you can override the default configuration by defining new values in /etc/emby-server.conf that is empty by default. Cheers. With the new beta release available, this default configuration change is also applied to beta. Any feedback will be appreciated. Thanks
dcrdev 255 Posted October 23, 2015 Posted October 23, 2015 Hi - first time posting here, I'd like to say that emby looks absolutely brilliant - I installed plex the other day on my home server and didn't like it because it relies heavily on the web services provided by plex i.e. it's not entirely self hosted. Then I came across emby which is entirely self hosted, has live tv support and integrated with Kodi very well - it ticks all the boxes for me. But then I came across a problem, there are no packages available for Fedora 22 which is what my server is running (the Server Edition). Now I think I'm competent enough to make it work, but I don't want to be constantly fixing things with every update; so for now I've not tried to install it. So my question is will emby continue to support Fedora, or has support died off? If the former is there any chance that emby can be made to work with the rpmfusion repos instead of epel (as epel isn't for Fedora) - from looking I believe that almost all the dependencies are available in rpmfusion. I'd be willing to help but whilst I'm competent in C# (on Windows) and (separately) packaging on Linux, I have no experience with mono. Thanks
fc7 123 Posted October 23, 2015 Posted October 23, 2015 There are people in the forum that managed to install Emby on Fedora 22. Just search around. We are planning to support Fedora 22, and we do provide packages in our repo but we didn't have time to test the F22 packages yet and come up with the correct installation instructions. As a side comment, if you are planning to use Emby on a stand-alone server/vm I would encourage you to switch to CentOS 7. Fedora is a fast moving target distro. They release a new version every few months and they only support current and previous releases, meaning for instance that since Fedora 22 release, Fedora 20 is not maintained anymore, not even for security updates. On the other hand, CentOS is based on RHEL which is a far more stable distro with long term support. Just my two cents.
dcrdev 255 Posted October 23, 2015 Posted October 23, 2015 (edited) Yeah I appreciate the stability that comes with CentOS, but unfortunately my server serves multiple purposes and some of the software I run requires newer libraries as dependencies. Also with the new server edition of Fedora, I think more and more people will be using it as a server platform. Believe me though I would use CentOS if I could! Fedora 23 comes out next Tuesday and with it Fedora 21 will reach the end of it's life - currently that's the only version you support? As I mentioned in my post, I know I could get it to work - but currently it's not as clear cut as installing a package i.e. I don't want to rely on something that'll likely break all the time. I'd prefer to wait for an officially supported solution. When you mention that there are F22 packages, but you haven't had time to test them - that seems to have been the case for quite a while? That's not a criticism - I really appreciate the work done by open source project, but surely there are people who'd be willing to help test such packages... I for one would - is this the F22 repo you speak of: ? http://download.opensuse.org/repositories/home:/emby/Fedora_22/home:emby.repo Edited October 23, 2015 by dcrdev
fc7 123 Posted October 23, 2015 Posted October 23, 2015 (edited) Yeah I appreciate the stability that comes with CentOS, but unfortunately my server serves multiple purposes and some of the software I run requires newer libraries as dependencies. Also with the new server edition of Fedora, I think more and more people will be using it as a server platform. Believe me though I would use CentOS if I could! Fedora 23 comes out next Tuesday and with it Fedora 21 will reach the end of it's life - currently that's the only version you support? As I mentioned in my post, I know I could get it to work - but currently it's not as clear cut as installing a package i.e. I don't want to rely on something that'll likely break all the time. I'd prefer to wait for an officially supported solution. When you mention that there are F22 packages, but you haven't had time to test them - that seems to have been the case since last year? That's not a criticism - I really appreciate the work done by open source project, but surely there are people who'd be willing to help test such packages... I for one would - is this the F22 repo you speak of: ? http://download.opensuse.org/repositories/home:/emby/Fedora_22/home:emby.repo Yes indeed that's the repo. Regarding F22 packages, they are as stable as any other Emby official packages it's just that we didn't test the installation steps which based on some other users experience seems different from F21. That's all. Feel free to try F22 Emby packages and if you have problems with the installation (use F21 installation instructions from Emby website as a guidance -ommit the epel part and use rpmfusion instead-) you can search this forum and if you don't find the correct answers just post here, we will try to help. With some luck we will end up with the official installation steps for F22 that will be published in Emby website. Also check this: http://emby.media/community/index.php?/topic/25865-fedora-22-support/&do=findComment&comment=254687 Edited October 23, 2015 by fc7
fc7 123 Posted October 24, 2015 Posted October 24, 2015 (edited) Yeah I appreciate the stability that comes with CentOS, but unfortunately my server serves multiple purposes and some of the software I run requires newer libraries as dependencies. Also with the new server edition of Fedora, I think more and more people will be using it as a server platform. Believe me though I would use CentOS if I could! Fedora 23 comes out next Tuesday and with it Fedora 21 will reach the end of it's life - currently that's the only version you support? As I mentioned in my post, I know I could get it to work - but currently it's not as clear cut as installing a package i.e. I don't want to rely on something that'll likely break all the time. I'd prefer to wait for an officially supported solution. When you mention that there are F22 packages, but you haven't had time to test them - that seems to have been the case for quite a while? That's not a criticism - I really appreciate the work done by open source project, but surely there are people who'd be willing to help test such packages... I for one would - is this the F22 repo you speak of: ? http://download.opensuse.org/repositories/home:/emby/Fedora_22/home:emby.repo We have tested F22 packages and after a minor change in the package it will install without problems. Just follow the instructions on Emby site. All you need to add to your setup is our repo. EPEL nor RPMFusion are needed at all in F22. Enjoy Edited October 24, 2015 by fc7
fc7 123 Posted October 24, 2015 Posted October 24, 2015 @Fedora users IMPORTANT: from now on we will do our best to follow Fedora release cycle regarding Emby packages support. We will try to provide new packages as soon as the latest Fedora version is out there but at the same time we will only maintain packages for current Fedora version and the previous release.For example: right now F22 is the latest Fedora release and we provide packages for F22 and F21. As soon as F23 is realeased and F21 enters end of life (EOL) we will provide packages for F23 and F22, but we will stop proving packages for 21. If you want to run Emby on any Fedora release that is already EOL (F20 and older releases as of today) you can use our official Docker container.
dcrdev 255 Posted October 26, 2015 Posted October 26, 2015 Trying to install this on a CentOS 7.1 system now, I get the following errors: Error: Package: python-pillow-2.0.0-17.gitd1c6db8.el7.x86_64 (@base) Requires: libwebp.so.4()(64bit) Removing: libwebp-0.3.0-3.el7.x86_64 (@base) libwebp.so.4()(64bit) Updated By: libwebp-0.4.3-9.3.x86_64 (home_emby) ~libwebp.so.5()(64bit) Error: Package: webkitgtk3-2.0.4-6.el7_0.1.x86_64 (@base) Requires: libwebp.so.4()(64bit) Removing: libwebp-0.3.0-3.el7.x86_64 (@base) libwebp.so.4()(64bit) Updated By: libwebp-0.4.3-9.3.x86_64 (home_emby) ~libwebp.so.5()(64bit) You could try using --skip-broken to work around the problem You could try running: rpm -Va --nofiles --nodigest I have epel release enabled - any ideas?
