murpjf88 2 Posted November 22, 2024 Posted November 22, 2024 Maybe I'm doing something wrong. I'm trying to edit the primary image for a collection (box set) by using a picture I found on the internet and i only get a small image instead of a full sized image. It doesn't matter what aspect ratio I use, it's always the same size. Any suggestions?
Luke 42289 Posted November 22, 2024 Posted November 22, 2024 Hi, are you referring to the Christmas movies one? If so, then it’s due to the image not being 2:3 aspect ratio. You can use any image you want, but the closer the aspect is to 2:3, the more it will fill the box. 1
