BMan1 5 Posted November 22, 2024 Posted November 22, 2024 Why is it every time I try to watch something I spend more time trying to fix it than watch something. Had issues, popup saying to re do database or downgrade. Uninstalled all emby addons Updated emby repository Still showing v10.x Tried to install the service first before the video part. Gets stuck on failed to install dependencies
quickmic 1709 Posted November 22, 2024 Posted November 22, 2024 (edited) Quote Why is it every time I try to watch something I spend more time trying to fix it than watch something. You are not expecting a serious answer, right? As there is almost no info in this post i could work with, I reply with the standard phrase: Try an upgrade to 11.X. If next-gen plugin gives you to much headache, you can also try embycon. It should have lower complexity. Edited November 22, 2024 by quickmic
