Neminem 1623 Posted February 2, 2025 Posted February 2, 2025 @Grimx00Have a look here, this might help you. 1
yocker 1414 Posted February 2, 2025 Posted February 2, 2025 @LukeCan we get the fix for the Intel problem that the other media center software have? It started out with just Arc cards but now seems like more and more people are having problems even with Intel iGPUs. If a fix from your side could be made, and it does look like it's possible, it would be absolutely wonderful! 3
gcorgnet 5 Posted February 4, 2025 Posted February 4, 2025 Hi, I would second this, please. I've downgraded kernels, reinstalled drivers and still can't get OpenCL Tone Mapping to work, and the log points at the exact same symptom described here. It looks like Jellyfin has a fix but I'd rather stay with Emby. Thanks
Luke 42242 Posted May 19, 2025 Posted May 19, 2025 OverrideGpuAddressSpace has been added on the beta channel. Thanks.
gcorgnet 5 Posted May 19, 2025 Posted May 19, 2025 Thanks for this @Luke. Could you please share how we are meant to use it? Does it need to be configured? Thanks
Luke 42242 Posted May 26, 2025 Posted May 26, 2025 On 5/19/2025 at 7:17 PM, gcorgnet said: Thanks for this @Luke. Could you please share how we are meant to use it? Does it need to be configured? Thanks There's nothing to configure. They are applied automatically and the gpu drivers will pick them up.
gcorgnet 5 Posted May 29, 2025 Posted May 29, 2025 Thanks for this. I have tried again today and HW transcoding still seems to break when Tone Mapping is enabled (resulting in SW transcoding happening and hammering my CPU) This is what I believe is the relevant error (also attached the original file for reference) 19:41:25.639 Stream mapping: 19:41:25.639 Stream #0:0 (hevc) -> scale_vaapi:default (graph 0) 19:41:25.639 hwmap:default (graph 0) -> Stream #0:0 (h264_vaapi) 19:41:25.639 Stream #0:1 -> #0:1 (truehd (native) -> mp3 (libmp3lame)) 19:41:25.639 Press [q] to stop, [?] for help 19:41:25.729 [AVHWDeviceContext @ 0x1dd6b80] Failed to get number of OpenCL platforms: -1001. 19:41:25.729 [hwmap@f2 @ 0x1fa2b80] Failed to created derived device context: -19. 19:41:25.729 [hwmap@f2 @ 0x1fa2b80] Failed to configure output pad on hwmap@f2 19:41:25.729 Error reinitializing filters! 19:41:25.729 Failed to inject frame into filter network: No such device 19:41:25.729 Error while processing the decoded data for stream #0:0 19:41:25.732 Conversion failed! 19:41:25.732 EXIT Any help would be appreciated, thanks (For reference, my set up is Emby 4.9.1.0 in Proxmox on a NUC8i7HNK (Hades Canyon) with an Intel CPU and an AMD GPU (AMD Radeon RX Vega M GL Graphics) ffmpeg-transcode-36c7def1-cf14-4a83-91cf-62f824cad55d_1.txt
Luke 42242 Posted June 11, 2025 Posted June 11, 2025 Hi, in the near future we'll have an updated ffmpeg build on the server beta channel, just FYI. 1
Grzegorz93 1 Posted September 14, 2025 Posted September 14, 2025 On 6/11/2025 at 5:22 AM, Luke said: Hi, in the near future we'll have an updated ffmpeg build on the server beta channel, just FYI. Which beta version is the most "stable" that solves this problem or approximately when will the stable version be released?
gcorgnet 5 Posted September 14, 2025 Posted September 14, 2025 I've got the latest beta and this doesn't seem solved. 1
Grzegorz93 1 Posted September 14, 2025 Posted September 14, 2025 2 hours ago, gcorgnet said: I've got the latest beta and this doesn't seem solved. Thank you.
Grzegorz93 1 Posted September 15, 2025 Posted September 15, 2025 On 6/11/2025 at 5:22 AM, Luke said: Hi, in the near future we'll have an updated ffmpeg build on the server beta channel, just FYI. How can we help you and the development team to resolve the tone mapping issue for Intel Arc cards as quickly as possible?
Luke 42242 Posted September 26, 2025 Posted September 26, 2025 On 9/15/2025 at 11:43 AM, Grzegorz93 said: How can we help you and the development team to resolve the tone mapping issue for Intel Arc cards as quickly as possible? Hi, the best way to help is to be ready to provide feedback on the beta channel as soon as we have this in. Thanks ! 1
