Luke 42237 Posted October 9, 2025 Posted October 9, 2025 3 hours ago, edin92 said: any news, update?? We have not been notified of approval or rejection. It is still in their review process. 1
Funkie 6 Posted October 28, 2025 Posted October 28, 2025 I received the below message this morning from the titan os team Hi Shaun, we have published the QA report on our partner portal, but have not yet received an updated version for retest from the Emby team. I have sent them a reminder today. 1
Funkie 6 Posted October 30, 2025 Posted October 30, 2025 Received this today so looking good now. Hi Shaun We have received the new version from Emby team which has passed our QA. We will start publishing of the app in our app store globally late today/tomorrow. Best, Lenart 1 1
juerg 0 Posted November 3, 2025 Posted November 3, 2025 As of Today i can still not see the app in the app store ....
Luke 42237 Posted November 3, 2025 Posted November 3, 2025 6 hours ago, juerg said: As of Today i can still not see the app in the app store .... @Funkiecan you?
ARNiTECT 4 Posted November 3, 2025 Posted November 3, 2025 (edited) The app is available now. I've downloaded, entered my pin, but can't connect to my server... Now I can't even enter text into the Host for the server IP... I just get a little white box with a yellow exclamation mark triangle. Restarting TV doesn't help. TV & remote on latest firmware. Tried wired & wifi. Edited November 3, 2025 by ARNiTECT
Luke 42237 Posted November 3, 2025 Posted November 3, 2025 13 minutes ago, ARNiTECT said: The app is available now. I've downloaded, entered my pin, but can't connect to my server... Now I can't even enter text into the Host for the server IP... I just get a little white box with a yellow exclamation mark triangle. Restarting TV doesn't help. TV & remote on latest firmware. Tried wired & wifi. Hi, can you please show a screenshot example? Thanks.
Luke 42237 Posted November 3, 2025 Posted November 3, 2025 3 minutes ago, ARNiTECT said: Have you setup https on your server? I wonder if these devices will only allow connections to https addresses.
ARNiTECT 4 Posted November 3, 2025 Posted November 3, 2025 I plugged in a USB keyboard so I can at least type; but trying IP or DNS name results in the above screenshot
ARNiTECT 4 Posted November 3, 2025 Posted November 3, 2025 I think I'm on http (lan only) - how do I change to https?
Luke 42237 Posted November 3, 2025 Posted November 3, 2025 25 minutes ago, ARNiTECT said: I think I'm on http (lan only) - how do I change to https? Have you setup https on your emby server?
ARNiTECT 4 Posted November 3, 2025 Posted November 3, 2025 26 minutes ago, Luke said: Have you setup https on your emby server? nope
Luke 42237 Posted November 3, 2025 Posted November 3, 2025 48 minutes ago, ARNiTECT said: nope OK I've sent a message to titan developers asking if communication to http addresses is allowed or not. We'll see what they say. 1
ARNiTECT 4 Posted November 3, 2025 Posted November 3, 2025 16 minutes ago, Luke said: OK I've sent a message to titan developers asking if communication to http addresses is allowed or not. We'll see what they say. Thanks Luke 1
ARNiTECT 4 Posted November 4, 2025 Posted November 4, 2025 18 hours ago, Luke said: Have you setup https on your emby server? I quickly setup https on my server. It works from other devices on the LAN, but Emby on my TitanOS TV still does not work ("we're unable to connect to the selected server right now...")
Papiscze 3 Posted November 4, 2025 Author Posted November 4, 2025 Hi, thanks for adding the app. I tried the app today and i'm also having trouble using the local IP. When i enter 192.168.x.x:8096, i get an error message, but i have found that when i use my public IP and the standard Emby HTTP port (8096), i can connect to the server successfully and everything works.
Luke 42237 Posted November 4, 2025 Posted November 4, 2025 3 hours ago, Papiscze said: Hi, thanks for adding the app. I tried the app today and i'm also having trouble using the local IP. When i enter 192.168.x.x:8096, i get an error message, but i have found that when i use my public IP and the standard Emby HTTP port (8096), i can connect to the server successfully and everything works. They responded and said it should be able to connect to LAN ip addresses, but I will have to let them know that it's not working. Thanks.
juerg 0 Posted November 5, 2025 Posted November 5, 2025 Same for me. I am using Emby only locally and not over https. Also to enter the IP is not possible with the remote, the keypad shows up very quickly an disapears, had to connect a USB keyboard. Jürg
Funkie 6 Posted November 5, 2025 Posted November 5, 2025 On 04/11/2025 at 13:40, Luke said: @Funkieare you able to connect? Hi Luke Sorry for the delay in responding, I have been away with work. App is available to me now, the keyboard works without issue with my remote but I cannot connect via any means. I have tried local ip on both 8096 and 8920, I have tried my external url on 443 and I have tried the connect option entering a pin via https://emby.media/pin but it is not connecting.
Funkie 6 Posted November 5, 2025 Posted November 5, 2025 The add server screen is where I end up after using the pin to connect, click on add server and we are back to the manual connect to server screen
Luke 42237 Posted November 5, 2025 Posted November 5, 2025 As the other user has mentioned, try using your remote address, assuming that you’ve setup remote access on your server.
Funkie 6 Posted November 5, 2025 Posted November 5, 2025 21 minutes ago, Luke said: As the other user has mentioned, try using your remote address, assuming that you’ve setup remote access on your server. Hi Luke If that message was for me, I explained in my previous post that I have tried all methods to connect including external address. I have emby on multiple devices connected on the internal network and my tablet is connected via external address, everything works as expected except this Philips tv with titan os. I have another Philips tv that has google tv os and that works as normal, as I said its just the titan os device with the issue. Let me know if you need any specific device details or further testing carried out. 1
juerg 0 Posted November 15, 2025 Posted November 15, 2025 Hello Luke Any news, as i am still not able to connect. I am using emby server only in my internal network with http on my windows pc and app on several android devices. All are working without any issue except tihis phillips tv can not find the server. Also is the pop up keyboard not showing up. Please help Regards Jürg
