junkrat 1 Posted November 21, 2024 Posted November 21, 2024 (edited) Probably a stupid question but do I have to set permissions somewhere for the Emby .spk install on a Synology NAS to allow Emby access to run comskip (also installed system wide via .spk) as a post process after a live TV recording has finished? I see the error log and the command it runs, then if I run the command in an ssh shell (copying directly from the log file) it works fine (hence my thinking maybe it's an Emby permissions thing maybe?) I think a key line from the error log is: System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (2): An error occurred trying to start process 'comskip --ini="/volume1/Plex Media/comskip.ini" ' with working directory '/volume1/@appstore/EmbyServer'. No such file or directory Both folders exist Any help would be amazing, thankyou Partial error log here on a test I was running: https://pastebin.com/jmURvsAr Edited November 21, 2024 by junkrat
Luke 42241 Posted November 21, 2024 Posted November 21, 2024 Hi, how did you configure the post processing settings?
junkrat 1 Posted November 21, 2024 Author Posted November 21, 2024 So in the recording post processing section I have: Post-processing application comskip --ini="/volume1/Plex Media/comskip.ini" Post-processor command line arguments (default) "{path}" I have a space after the comskip.ini" in Post-processing application
Carlo 4561 Posted November 21, 2024 Posted November 21, 2024 Check this thread. It's a bit long but covers a lot of things you may need to adjust or set permissions. Follow the directions in the first post and refer back to the thread if you have an issue or need additional help. Carlo
junkrat 1 Posted November 21, 2024 Author Posted November 21, 2024 Hi Carlo, Sorry which thread? I clicked on the URL in your signature (which points to a 404 not found page, changing it to https://support.emby.media/support/index.html fixes it) but it looks like the general support page and I'm not sure where to start looking Thanks for the help on this, getting comskip to run on the system was a big hurdle and this is the last piece of the puzzle haha
Carlo 4561 Posted November 22, 2024 Posted November 22, 2024 Thanks, it used to redirect. I changed it up a bit. Sorry about that. It's 28 pages long. I wanted to show you this thread as it has real useful info in it as well as shows how to skip vs cut commercials in Emby. Carlo
Solution junkrat 1 Posted November 23, 2024 Author Solution Posted November 23, 2024 Fantastic thankyou! Wading through that thread was informative - the key bit of info for anyone else that has installed comskip via the Synology community package method was how to break up the commands in the post process. In live TV advanced settings for Emby I how have: Post-processing application /volume1/@appstore/comskip/bin/comskip/comskip Post-processor command line arguments (default) --ini="/volume1/Plex Media/comskip.ini" "{path}" and this works. The .ini file is the same that comes with the comskip installation and I put it in a folder that Emby already had permissions for. I also gave permission to emby to access the @appstore location of comskip 1
Jator 13 Posted January 2, 2025 Posted January 2, 2025 Thanks for the above, it seems you may have found the solution I posted about here:
Jator 13 Posted February 17, 2025 Posted February 17, 2025 On 11/22/2024 at 7:00 PM, junkrat said: I also gave permission to emby to access the @appstore location of comskip Sorry to ask a basic question, but how do you grant access to a System Internal User account such as Emby within Synology. I'm not seeing a directive/walk-through in my search online.
GrimReaper 4896 Posted February 17, 2025 Posted February 17, 2025 18 minutes ago, Jator said: how do you grant access to a System Internal User account such as Emby within Synology
Jator 13 Posted February 17, 2025 Posted February 17, 2025 20 minutes ago, GrimReaper said: Thanks Grim. I have already setup a media folder where I store my recordings and assigned EmbyUser, but the /volume/@appxxxx directories are not shared directories and as such I am unable to change permissions using the Shared Folder application within Synology web portal as far as I can tell. I have created a folder /volume1/@appdata/EmbyServer/comskip and placed both the comskip and comskip.ini and changed the owner and permissions to match the other files within Emby's folder. Repointed the paths in Emby's websettings for post processing and recording a show now to see if that works. Crossing my fingers.
