seanbuff 1353 Posted November 19, 2014 Posted November 19, 2014 Current Server Ver: 3.0.5424.1 After installing the latest MBPlus server plugin and restarting MBS - I am presented with: At which point MBS stops. Unable to be restarted. Strangely I see in the logs it's complaining about metadata missing from TV Series, metadata that was previously fully populated. On the filesystem, it appears to have been overwritten with 0kb xml files. With an odd date to match. This is across multiple shows so it can't be accurate. MBS was working perfectly fine until just before the restart, all metadata has been in place for months. No other metadata system is accessing the media store. MB is the only one. What is the quickest way for me to get back on my feet and get MBS to start without errors? TIA. Server logs here and unhandled error log here
Luke 42184 Posted November 19, 2014 Posted November 19, 2014 Go into the server's program data folder/plugins and remove the MBPlus dll for now.
Luke 42184 Posted November 19, 2014 Posted November 19, 2014 As far as the metadata, there's no way to know how that happened, but the server can recover from those 0 byte files, although i would still delete them.
ebr 16307 Posted November 19, 2014 Posted November 19, 2014 I have no idea how that is happening. Both parameters sent to that method are null coalesced. @@Luke will it throw that exception if the argument is emptystring?
Solution ebr 16307 Posted November 19, 2014 Solution Posted November 19, 2014 @@seanbuff on a hunch that that method is throwing for an empty string, I just covered that scenario in MB Plus. Please install 1.0.4.1 and see if the server starts normally. Thanks. 1
seanbuff 1353 Posted November 19, 2014 Author Posted November 19, 2014 @@seanbuff on a hunch that that method is throwing for an empty string, I just covered that scenario in MB Plus. Please install 1.0.4.1 and see if the server starts normally. Thanks. @@ebr is there another way I can download that version if I can't start the server at all? I should I manually remove it as @@Luke suggested and let it update again to 1.0.4.1?
seanbuff 1353 Posted November 19, 2014 Author Posted November 19, 2014 Never mind, it seems to be downloading it automatically when I attempted another start of MBS. Will update this soon...
seanbuff 1353 Posted November 19, 2014 Author Posted November 19, 2014 Thanks guys, everything looks like it's resolved since updating to MBPlus 1.0.4.1 MBS starts normally once again.
daedalus 434 Posted November 29, 2014 Posted November 29, 2014 since today i also get this unhandled exception on startup disabling mbplus by renaming the dll fixes the startup problem before mbplus was working normal server log server-63552804189.txt and unhandled exceptoion log unhandled_d2ede180-6f8a-4655-b073-eed14349bc6d.txt
ebr 16307 Posted November 29, 2014 Posted November 29, 2014 Does it work if you go back to the beta version of the server?
daedalus 434 Posted November 29, 2014 Posted November 29, 2014 (edited) ok seems to be that something is completely going wrong here now it wont start anymore even without mbplus i set it up from the scratch and now everything works fine again sry for bothering ps: worked pretty fast with the neat server configuration backup plugin :thumpsup: Edited November 29, 2014 by daedalus
