whubbartt 1 Posted November 20, 2024 Posted November 20, 2024 Hi all, let me explain. I have two tuner sources 1) My homerun HD device 2) M3u Playlist that has categories for programming. I have 2 sources for epg When I go to guide on PC I have an "all" selection on a slide bar that will show my local HD HOme run channels with epg. When I go to guide on Android TV the "All" is not available and none of my guide data shows for my HD Home run device. Also in Android TV none of it has a slide bar. I would love to see both of those features in the Android TV apk. On both I can select groups but never can I get any guide listings from my HD home run except on a web login for pc. I cannot see my epg or channels when using Android TV. Maybe this isn't a feature request but maybe overlooked? Thank You, WH
ebr 16337 Posted November 20, 2024 Posted November 20, 2024 Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
whubbartt 1 Posted November 20, 2024 Author Posted November 20, 2024 Hi, this is where I downloaded from - The google play store. Although Emby comes up two times. Which one should i grab?
ebr 16337 Posted November 20, 2024 Posted November 20, 2024 4 hours ago, whubbartt said: Which one should i grab? Emby for Android
Luke 42243 Posted November 20, 2024 Posted November 20, 2024 @whubbarttplease let us know if this helps. Thanks !
whubbartt 1 Posted November 21, 2024 Author Posted November 21, 2024 Two versions show on the google play store that are for Android. I have the Android TV one currently.
seanbuff 1356 Posted November 21, 2024 Posted November 21, 2024 11 minutes ago, whubbartt said: I have the Android TV one currently. The devs are suggesting you install the non-TV variant and see how it compares. You can install and run both apps.
Luke 42243 Posted November 21, 2024 Posted November 21, 2024 @whubbarttcan you please try it and let us know how it compares for you? Thanks !
whubbartt 1 Posted November 21, 2024 Author Posted November 21, 2024 I installed the other version, but I am still not getting the epg from my first tuner so I can't tune any channels from it. I reloaded tuner and epg guide in live tv. I still don't see a slide bar or anything that says "any" on the available options. thanks for the help WH
whubbartt 1 Posted November 21, 2024 Author Posted November 21, 2024 Do I have to go through every channel on my home run and add a tag for those to show?
Luke 42243 Posted November 22, 2024 Posted November 22, 2024 8 hours ago, whubbartt said: Do I have to go through every channel on my home run and add a tag for those to show? Hi, why would you need to do this?
Luke 42243 Posted November 22, 2024 Posted November 22, 2024 9 hours ago, whubbartt said: I installed the other version, but I am still not getting the epg from my first tuner so I can't tune any channels from it. Hi, what version number was it?
whubbartt 1 Posted November 22, 2024 Author Posted November 22, 2024 Luke in response to Hi, why would you need to do this? Ans I don't want to but it's the only way I can get the first tuner to show epg and be able to tune the channel. Version # Emby for android 3.4.20
Luke 42243 Posted November 22, 2024 Posted November 22, 2024 13 minutes ago, whubbartt said: Luke in response to Hi, why would you need to do this? Ans I don't want to but it's the only way I can get the first tuner to show epg and be able to tune the channel. Version # Emby for android 3.4.20 Hi, can you please show a screenshot example of your live tv guide in 3.4.20? Thanks.
whubbartt 1 Posted November 22, 2024 Author Posted November 22, 2024 Yes here is a screen shot. I have one channel cbs from my first tuner because I put a tag on it. After that only lists tuner 2. It's missing 579 channels from tuner 1
ebr 16337 Posted November 22, 2024 Posted November 22, 2024 Hi. Are the channels missing or just the guide data?
whubbartt 1 Posted November 22, 2024 Author Posted November 22, 2024 Channels missing too unless I give each ch a tag
Luke 42243 Posted November 22, 2024 Posted November 22, 2024 32 minutes ago, whubbartt said: Channels missing too unless I give each ch a tag Maybe you have a filter activated? Try clicking the sort button next to the date. What does the resulting dialog look like?
whubbartt 1 Posted November 24, 2024 Author Posted November 24, 2024 I uninstalled all versions of emby and reinstalled the current version reset everything up with tuners and live and now I have my content. It's still a bit clumsy to manage between tuners but it's working now. Thank You so much for your assistance.
Luke 42243 Posted November 25, 2024 Posted November 25, 2024 6 hours ago, whubbartt said: I uninstalled all versions of emby and reinstalled the current version reset everything up with tuners and live and now I have my content. It's still a bit clumsy to manage between tuners but it's working now. Thank You so much for your assistance. Hi, what do you think is clunky?
whubbartt 1 Posted November 25, 2024 Author Posted November 25, 2024 I like the program, but I am finding its not very friendly to find content unless you have tags on the channels. That's not a huge issue. I will just have to go through and make tags for each network.
Luke 42243 Posted November 25, 2024 Posted November 25, 2024 14 hours ago, whubbartt said: I like the program, but I am finding its not very friendly to find content unless you have tags on the channels. That's not a huge issue. I will just have to go through and make tags for each network. HI, this isn't true. You do not need tags. I think we need to better understand what you're doing that's making you feel like this is a requirement, because it is not.
