Termindiego25 5 Posted August 7, 2025 Posted August 7, 2025 11 hours ago, Luke said: Hi there, please attach the Emby server log from when the problem occurred: How to Report a Problem Thanks! Hello! I played some movies on the LG TV that works first and then did the same on the LG TV isn't working. Here you are the logs with debug enabled. If I can give you more information or try to test something just send me a message embyserver.txt
Luke 42239 Posted August 8, 2025 Posted August 8, 2025 On 8/7/2025 at 2:47 AM, Termindiego25 said: Hello! I played some movies on the LG TV that works first and then did the same on the LG TV isn't working. Here you are the logs with debug enabled. If I can give you more information or try to test something just send me a message embyserver.txt 1.78 MB · 1 download Hi, please attach the ffmpeg log as well. Thanks.
Termindiego25 5 Posted August 9, 2025 Posted August 9, 2025 (edited) 13 hours ago, Luke said: Hi, please attach the ffmpeg log as well. Thanks. Since there are several ffmpeg files in the logs tab, I have downloaded all of them from the log date and put them here ffmpeg-transcode-1d113a7f-5821-43d6-81e9-4006bc704891_1.txt ffmpeg-transcode-4f6993ff-338e-4cde-ab68-fe202fdb2715_1.txt ffmpeg-transcode-7fb6b910-4349-46a4-9739-558ab135bb09_1.txt ffmpeg-transcode-9cefe6cf-4522-4af0-821b-d068506986fc_1.txt ffmpeg-transcode-15d3aa7f-f358-4d26-be13-663603c8035d_1.txt ffmpeg-transcode-39cc429d-ea50-4a93-aa36-0e02c726a523_1.txt ffmpeg-transcode-63e52667-d64b-4c7d-b012-86abd34bbe07_1.txt ffmpeg-transcode-b6c4bf12-566e-45c9-9da4-c6c49077412a_1.txt ffmpeg-transcode-ddbfa4b3-234a-408d-a854-e8ea07770ef5_1.txt ffmpeg-transcode-e9004151-1f25-45a5-a820-87c390a6bc45_1.txt Edited August 9, 2025 by Termindiego25
Luke 42239 Posted September 24, 2025 Posted September 24, 2025 On 8/9/2025 at 4:17 AM, Termindiego25 said: Since there are several ffmpeg files in the logs tab, I have downloaded all of them from the log date and put them here ffmpeg-transcode-1d113a7f-5821-43d6-81e9-4006bc704891_1.txt 5.78 kB · 1 download ffmpeg-transcode-4f6993ff-338e-4cde-ab68-fe202fdb2715_1.txt 63.26 kB · 0 downloads ffmpeg-transcode-7fb6b910-4349-46a4-9739-558ab135bb09_1.txt 5.78 kB · 0 downloads ffmpeg-transcode-9cefe6cf-4522-4af0-821b-d068506986fc_1.txt 23.23 kB · 0 downloads ffmpeg-transcode-15d3aa7f-f358-4d26-be13-663603c8035d_1.txt 5.78 kB · 0 downloads ffmpeg-transcode-39cc429d-ea50-4a93-aa36-0e02c726a523_1.txt 5.77 kB · 0 downloads ffmpeg-transcode-63e52667-d64b-4c7d-b012-86abd34bbe07_1.txt 5.78 kB · 0 downloads ffmpeg-transcode-b6c4bf12-566e-45c9-9da4-c6c49077412a_1.txt 5.78 kB · 0 downloads ffmpeg-transcode-ddbfa4b3-234a-408d-a854-e8ea07770ef5_1.txt 5.78 kB · 0 downloads ffmpeg-transcode-e9004151-1f25-45a5-a820-87c390a6bc45_1.txt 5.78 kB · 0 downloads Hi, can you please update to the latest build of the server? Are you still having this issue with that?
