How Schedule Qboost Memory Optimization... for Emby
Hispanico957
Since even asking QNap support they don't give info/help to be able to use the utility, after several attempts I succeeded and I explain how:
- using WinSCP  or Filezilla etc. create a "Nas" folder (or name of your choice) in share/CACHEDEV1_DATA
- create a .sh file in the folder (which I called cache) using the nano or Vi editor with the following content and save it
#!/bin/sh
/share/CACHEDEV1_DATA/Nas/cache.sh
using Putty in SSH mode go to the folder and type the following command to make the file executable
chmod +x cache.sh
then with the editor nano open crontab
nano /etc/config/crontab
and insert the following lines at the bottom of the list
0 19 * * * /share/CACHEDEV1_DATA/Nas/cache.sh
0 21 * * * /share/CACHEDEV1_DATA/Nas/cache.sh
0 23 * * * /share/CACHEDEV1_DATA/Nas/cache.sh
which means that QBoost (or clear cache utility) starts every day at 19, 21 and 23.
save the crontab file modified in this way and then give the following command to reload the crontab file:
crontab /etc/config/crontab && /etc/init.d/crond.sh restart
This utility and routine is very important using an Emby server on my QNAP, which uses a lot of memory when using.
Attached is a before and after example
Hispa
Notes:
- QNap page of reference https://www.qnap.com/en-in/how-to/faq/article/how-to-schedule-qboost-memory-optimization
- QNap page for scheduling https://www.qnap.com/es-es/how-to/faq/article/how-to-add-jobs-to-crontab-to-schedule-a-job
- crontab timing/scheduling reference page https://crontab.guru/
- reference page drop caches to clear cache https://unix.stackexchange.com/questions/17936/setting-proc-sys-vm-drop-caches-to-clear-cache
Edited by Hispanico957
  • Thanks 1
Hispanico957
Sorry but I mistyped the command in the .sh file (cache.sh) and here below I report everything correctly and revised:
#!/bin/sh
/bin/echo 1 > /proc/sys/vm/drop_caches
chmod +x cache.sh
and insert the following line at the bottom of the list
0 19-23/2 * * * /share/CACHEDEV1_DATA/Nas/cache.sh
which mean that QBoost (or clear cache utility) starts every day at 19, 21 and 23 (every 2 hours)
Hispa
  • Thanks 1
