Pietrogramma 3 Posted November 17, 2024 Posted November 17, 2024 Hi everyone, I've been a happy user of Emby for several years and I find it really brilliant. The other day I ripped two DVDs of a Led Zeppelin concert, which I called "Led Zeppelin DVD1" and "Led Zeppelin DVD2", which I copied into my multimedia files folder and Emby cataloged them for me with a single entry and all Inside the item I also inserted the second DVD (I attach photos to be even clearer). I think this solution is brilliant and so I ripped two other DVDs which I called "George Michael DVD1" "George Michael DVD2" but emby this time cataloged them as two DVDs separate from each other, how do I insert the two DVDs in a single card (as done with the Led Zeppelin one). I hope I explained myself well. Hello and thanks
Neminem 1592 Posted November 17, 2024 Posted November 17, 2024 We need logs, screenshots of folders folders/file naming. Otherwise this is the best guess you will get. Movie Naming | Emby Documentation Compair naming and do the same as you did with the Led Zeppelin concert.
Luke 42183 Posted November 17, 2024 Posted November 17, 2024 Hi there, yes, how are your files named and organized?
Pietrogramma 3 Posted November 17, 2024 Author Posted November 17, 2024 Thanks the Neminem's help, I solved the iusse...I renamed the file adding at the end DVD1 (for the firtse file) and DVD2 for the second e now all work fine Thnaks again an ciao from Italy (sorry for bad english) 1
Pietrogramma 3 Posted November 17, 2024 Author Posted November 17, 2024 (edited) I thought I had solved it by adding DVD1, DVD2 etc. to the end of the name, but I was wrong. A little while ago I tried renaming two files from the same concert to David Gilmour - Live at Pompeii.DVD1.mkv and David Gilmour - Live at Pompeii.DVD2.mkv (see attached image), hoping that emby would create me a single tab with the two files inside but instead it created two separate tabs, one for each file (see second attached image) Edited November 17, 2024 by Pietrogramma
visproduction 328 Posted November 18, 2024 Posted November 18, 2024 CSS Styles could adjust this info line to be visible and wrap on Emby Web. It will not work on Emby Android or other versions. .cardText { overflow: visible !important; } .cardText.cardTextCentered.cardText-first-padded.cardText-first, .cardText-first { font-size: 12px; margin: 0 0 -5px; padding: 2px 1px; white-space: -moz-pre-wrap; white-space: -o-pre-wrap; white-space: -pre-wrap; white-space: pre-wrap; } 1
