jrochao2 3 Posted November 16, 2024 Posted November 16, 2024 Hi, I have added a new folder to the library to scan, but it does not go beyond 95% I have restarted the server several times but it does not finish scanning, it stops at 95% every time. Any ideas? embyserver.txt
visproduction 335 Posted November 16, 2024 Posted November 16, 2024 Vaapi codec not compatible with ffmpeg? see: https://trac.ffmpeg.org/wiki/Hardware/VAAPI line 1381 Quote 2024-11-16 03:02:19.163 Info VaapiCodecProvider: ProcessRun 'ffdetect_vaencdec' Execute: /opt/emby-server/bin/ffdetect -hide_banner -show_program_version -loglevel 48 -show_error -show_log 40 vaencdec -print_format json Playback error creates C+ null? lines 2381+ Happens 26 times. Quote 2024-11-16 03:20:32.827 Info Server: http/1.1 POST http://host1:8096/emby/Sessions/Playing. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; AFTSSS Build/PS7685.4486N) 2024-11-16 03:20:32.840 Error Server: Error processing request *** Error Report *** Version: 4.8.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 4.15.0-191-generic (buildd@lcy02-amd64-032) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #202-Ubuntu SMP Thu Aug 4 01:49:29 UTC 202 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system System.ArgumentNullException: System.ArgumentNullException: Value cannot be null. (Parameter 'key') at System.ThrowHelper.ThrowArgumentNullException(String name) at System.Collections.Concurrent.ConcurrentDictionary`2.GetOrAdd(TKey key, Func`2 valueFactory) at Emby.Server.Implementations.Session.SessionManager.OnPlaybackStart(PlaybackStartInfo info, SessionInfo session) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost httpHost, IServerApplicationHost appHost, IRequest httpReq, IResponse httpRes, IStreamHelper streamHelper, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: System.Collections.Concurrent TargetSite: Void ThrowArgumentNullException(System.String) Strange error attempt to connect to outside html URL fails? lines 2573+ Quote 2024-11-16 03:21:28.726 Info Server: http/1.1 Response 204 to host2. Time: 4ms. POST http://host1:8096/emby/Sessions/Playing/Progress?X-Emby-Client=Emby for Android&X-Emby-Device-Name=Galaxy Tab A (2016)&X-Emby-Device-Id=668cd01e3702507a&X-Emby-Client-Version=3.4.20&X-Emby-Token=x_secret1_x&X-Emby-Language=es&reqformat=json 2024-11-16 03:21:29.888 Error HttpClient: Connection to http://test2024embgoor.access.ly:25461/DGLHt2utdvkZ/UX2ZTE2tRSdL/1094896 timed out 2024-11-16 03:21:29.892 Error Server: Error processing request *** Error Report *** Version: 4.8.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 4.15.0-191-generic (buildd@lcy02-amd64-032) (gcc version 7.5.0 (Ubuntu 7.5.0-3ubuntu1~18.04)) #202-Ubuntu SMP Thu Aug 4 01:49:29 UTC 202 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to http://test2024embgoor.access.ly:25461/DGLHt2utdvkZ/UX2ZTE2tRSdL/1094896 timed out ---> System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 20 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ... Do you have video thumbnails turned on? This media file has some issues and it looks like thumbnails cannot be extracted to jpg. line 31263 Quote System.Exception: System.Exception: Error running ffmpeg quick-extract-image for file:"/mnt/series_sh2/00.SERIES/El Caso Cenicienta (2024)/Temporada 01/El Caso Cenicienta - S01E02 - Episodio 2 [1080p WEB-DL h264].mkv" - Command: -f matroska -threads 1 -i file:"/mnt/series_sh2/00.SERIES/El Caso Cenicienta (2024)/Temporada 01/El Caso Cenicienta - S01E02 - Episodio 2 [1080p WEB-DL h264].mkv" -map 0:4 -update 1 -vsync 0 -f image2 "/var/lib/emby/cache/temp/0eedc4f5-bc5d-4887-9def-c5b23c478a2d.jpg" I am unsure of all the reasons on these log entries. Hopefully this is helpful for someone to do a code review.
darkassassin07 674 Posted November 16, 2024 Posted November 16, 2024 When the scan appears to be 'stuck', is emby still actively spitting out lines to the log file? Right up to the end of the provided log, there's lines that suggest the scan is still running, file by file. "2024-11-16 11:03:14.762 Info MediaProbeManager: ProcessRun 'ffprobe'....." The scan percentage displayed in the dashboard is often misleading, especially with large libraries. The first ~90% always speeds by, but It can appear to be stuck during the last 10% while it is still working away on time consuming tasks. Just verify there is still activity in the logs (ignoring things like playback progress reports) and wait. Patience is the key.
Luke 42243 Posted November 17, 2024 Posted November 17, 2024 Also @jrochao2please try removing these plugins: 2024-11-16 03:02:17.560 Info App: Loading ChapterApi, Version=1.3.0.10, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/ChapterApi.dll 2024-11-16 03:02:17.560 Info App: Loading statistics, Version=3.3.1.1, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Statistics.dll 2024-11-16 03:02:17.560 Info App: Loading Emby.MediaInfo, Version=1.0.1.20, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.MediaInfo.dll 2024-11-16 03:02:17.560 Info App: Loading VantagePoint, Version=2.1.0.5, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/VantagePoint.dll Then restart the server and see if this helps with your library scan performance. Please let us know how things compare. Thanks.
Luke 42243 Posted December 9, 2024 Posted December 9, 2024 On 11/17/2024 at 3:26 AM, jrochao2 said: these is my plugins actually @jrochao2did you try what I suggested?
jrochao2 3 Posted December 10, 2024 Author Posted December 10, 2024 Yes, but I still have problems, the problem is not that it finishes scanning, but that when scanning it sets the scan date to the date I created the folder in the gallery. That is, I add the file yesterday 12/09/2024 and the added date that appears in embu is 11/29/2023. And I don't know why it happens, if I change the date manually it works fine. It doesn't happen in all folders, only in certain ones, so it's not the rclone assembly, it's something in the scan.
Luke 42243 Posted December 10, 2024 Posted December 10, 2024 8 hours ago, jrochao2 said: Yes, but I still have problems, the problem is not that it finishes scanning, but that when scanning it sets the scan date to the date I created the folder in the gallery. That is, I add the file yesterday 12/09/2024 and the added date that appears in embu is 11/29/2023. And I don't know why it happens, if I change the date manually it works fine. It doesn't happen in all folders, only in certain ones, so it's not the rclone assembly, it's something in the scan. HI, what is your date added behavior configured to?
jrochao2 3 Posted December 10, 2024 Author Posted December 10, 2024 7 hours ago, darkassassin07 said: I have changed It. I didn't have that option selected. What I don't understand is why some galleries are selected and others aren't. I'll scan again tonight and I'll tell you tomorrow.
Happy2Play 9812 Posted December 10, 2024 Posted December 10, 2024 Note this option will have no affect any already imported media as they all already contain the info in the database and nfo file if you write them.
jrochao2 3 Posted December 11, 2024 Author Posted December 11, 2024 20 hours ago, darkassassin07 said: This has been the solution, I don't know how it has changed... It will be my children when they take the mobile phone and touch everything, they are 4 years old 1
