GunbleR 5 Posted November 14, 2024 Posted November 14, 2024 got a bit of a weird issue. emby 4.8.10.0 truenas: ElectricEel-24.10.0.2 client: pc Brave browser, pc emby theater from store, android brave browser, android emby theater reverse proxy: swag docker using ipv4 only after upgrading truenas dragonfish to electric eel(switch from kubernetes to docker compose), when playing HEVC files with bitrate above 4Mbps on auto quality emby always forces 1080P/4Mbsp transcoding. the ways to direct play are either set quality to 1080/60(or 4K/200) or to connect directly to container on http port without reverse proxy. tried to install clean container from truenas apps, switching to npm reverse proxy in emby log i found that Bitrate exceeds DirectPlay : Spoiler 2024-11-14 22:11:23.439 Info Server: http/1.1 POST http://host5/emby/Items/1893/PlaybackInfo?UserId=da2780d8d9a14179aa161a97de36365f&StartTimeTicks=0&IsPlayback=false&AutoOpenLiveStream=false&MaxStreamingBitrate=4000002&X-Emby-Client=Emby Web&X-Emby-Device-Name=Brave Windows&X-Emby-Device-Id=&X-Emby-Client-Version=4.8.10.0&X-Emby-Token=x_secret1_x&X-Emby-Language=en-gb&reqformat=json. Source Ip: host6, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/130.0.0.0 Safari/537.36 2024-11-14 22:11:23.510 Info App: User policy for MyEmbyUser. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True 2024-11-14 22:11:23.524 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 5284045, max bitrate: 4000002 2024-11-14 22:11:23.524 Info App: Bitrate exceeds DirectStream limit: media bitrate: 5284045, max bitrate: 4000002 2024-11-14 22:11:23.557 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 5284045, max bitrate: 4000002 2024-11-14 22:11:23.557 Info App: Bitrate exceeds DirectStream limit: media bitrate: 5284045, max bitrate: 4000002 2024-11-14 22:11:23.572 Info App: Bitrate exceeds DirectPlay limit: media bitrate: 5284045, max bitrate: 4000002 2024-11-14 22:11:23.572 Info App: Bitrate exceeds DirectStream limit: media bitrate: 5284045, max bitrate: 4000002 nginx config: Quote server { listen 443 ssl http2; listen [::]:443 ssl http2; set $upstream_app 10.0.3.14; set $upstream_port 30072; set $upstream_proto http; access_log /config/log/nginx/emby4-access.log main; error_log /config/log/nginx/emby4-error.log; server_name emby.example.com; include /config/nginx/ssl/example.com.conf; include /config/nginx/ssl.conf; client_max_body_size 0; location / { include /config/nginx/proxy.conf; include /config/nginx/resolver.conf; proxy_pass $upstream_proto://$upstream_app:$upstream_port; proxy_set_header Range $http_range; proxy_set_header If-Range $http_if_range; } } proxy.conf: ## Version 2023/02/09 - Changelog: https://github.com/linuxserver/docker-swag/commits/master/root/defaults/nginx/proxy.conf.sample # Timeout if the real server is dead proxy_next_upstream error timeout invalid_header http_500 http_502 http_503; # Proxy Connection Settings proxy_buffers 32 4k; proxy_connect_timeout 240; proxy_headers_hash_bucket_size 128; proxy_headers_hash_max_size 1024; proxy_http_version 1.1; proxy_read_timeout 240; proxy_redirect http:// $scheme://; proxy_send_timeout 240; # Proxy Cache and Cookie Settings proxy_cache_bypass $cookie_session; #proxy_cookie_path / "/; Secure"; # enable at your own risk, may break certain apps proxy_no_cache $cookie_session; # Proxy Header Settings proxy_set_header Connection $connection_upgrade; proxy_set_header Early-Data $ssl_early_data; proxy_set_header Host $host; proxy_set_header Proxy ""; proxy_set_header Upgrade $http_upgrade; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Host $host; proxy_set_header X-Forwarded-Method $request_method; proxy_set_header X-Forwarded-Port $server_port; proxy_set_header X-Forwarded-Proto $scheme; proxy_set_header X-Forwarded-Server $host; proxy_set_header X-Forwarded-Ssl on; proxy_set_header X-Forwarded-Uri $request_uri; proxy_set_header X-Original-Method $request_method; proxy_set_header X-Original-URL $scheme://$http_host$request_uri; proxy_set_header X-Real-IP $remote_addr; Spoiler {"Protocol":"File","Id":"a02882a711db4927fab1d80dd2157095","Path":"/mnt/d/+Tv Shows/Survivor/Season 47/Survivor - S47E06 - Feel the FOMO [MeGusta].mkv","Type":"Default","Container":"mkv","Size":2554857043,"Name":"Survivor - S47E06 - Feel the FOMO [MeGusta]","IsRemote":false,"HasMixedProtocols":false,"RunTimeTicks":38680320000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"hevc","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","TimeBase":"1/1000","VideoRange":"SDR","DisplayTitle":"1080p HEVC","IsInterlaced":false,"BitRate":5284045,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Height":1080,"Width":1920,"AverageFrameRate":30,"RealFrameRate":30,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p10le","Level":120,"IsAnamorphic":false,"ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None","AttachmentSize":0},{"Codec":"eac3","Language":"eng","TimeBase":"1/1000","DisplayTitle":"English EAC3 5.1 (Default)","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":true,"IsForced":false,"IsHearingImpaired":false,"Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None","AttachmentSize":0},{"Codec":"ass","Language":"eng","TimeBase":"1/1000","Title":"English (SDH)","DisplayTitle":"English (ASS)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None","AttachmentSize":0,"SubtitleLocationType":"InternalStream"},{"Codec":"srt","Language":"en","DisplayTitle":"English (SRT)","DisplayLanguage":"English","IsInterlaced":false,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Type":"Subtitle","Index":3,"IsExternal":true,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/mnt/d/+Tv Shows/Survivor/Season 47/Survivor - S47E06 - Feel the FOMO [MeGusta].en.srt","Protocol":"File","ExtendedVideoType":"None","ExtendedVideoSubType":"None","ExtendedVideoSubTypeDescription":"None","AttachmentSize":0}],"Formats":[],"Bitrate":5284045,"RequiredHttpHeaders":{},"AddApiKeyToDirectStreamUrl":false,"ReadAtNativeFramerate":false,"ItemId":"1893"} >>>>>> User policy for MyEmbyUser Enable Playback Remuxing: True Enable Video Playback Transcoding: True Enable Audio Playback Transcoding: True >>>>>> Hardware Encoders for h264 [X] VAAPI Xeon E3-1200 v3/4th Gen Core - H.264 (AVC) [X] VAAPI Tonga XT / Amethyst XT [1] - H.264 (AVC) >>>>>> Selected Codecs Decoder Automatic software decoder Encoder x264 Max Bitrate: 781 Mbit/s Color Formats: YUV420P, YUVJ420P, YUV422P, YUVJ422P, YUV444P, YUVJ444P, NV12, NV16, NV21, YUV420P10, YUV422P10, YUV444P10, NV20, GRAY8, GRAY10 - Bit Depths: 8, 10, 12, 14 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) >>>>>> FindVideoEncoder - MediaType: h264, UseHardwareCodecs: True, HWA-Mode: Automatic Warning: Hardware acceleration is not available as it requires a valid Premiere Subscription Info Checking: 'x264' Info Check successful - selecting 'x264' >>>>>> FindVideoDecoder - MediaType: hevc, UseHardwareCodecs: True, HWA-Mode: Automatic Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' >>>>>> Processing Plan Name CanDoInHW WillDoInHW Reason Automatic software decoder >> False False Software Codec VideoInput >> False False Not a hardware decoder ColorConversion >> False False VideoOutput >> False False Not a hardware encoder x264 >> False False Software Codec >>>>>> Video Processing Steps for [0:0]: H.265 (HEVC) Step HW-Context Format SW-Format Size Next HEVC >> - yuv420p10 yuv420p10 1920x1080 >> format format >> - yuv420p yuv420p 1920x1080 >> /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-9f91cf11-8c27-49ad-9071-518eb102fafd_1graph.txt" -copyts -start_at_zero -f matroska,webm -c:v:0 hevc -noautorotate -i "/mnt/d/+Tv Shows/Survivor/Season 47/Survivor - S47E06 - Feel the FOMO [MeGusta].mkv" -filter_complex "[0:0]format@f1=pix_fmts=yuv420p[f1_out0]" -map [f1_out0] -map 0:1 -sn -c:v:0 libx264 -g:v:0 90 -maxrate:v:0 3616002 -bufsize:v:0 7232004 -sc_threshold:v:0 0 -keyint_min:v:0 90 -r:v:0 30 -pix_fmt:v:0 yuv420p -preset:v:0 veryfast -profile:v:0 high -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -filter:a:0 "volume=2" -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/config/transcoding-temp/5C932A/5C932A.m3u8" -segment_list_type m3u8 -segment_time 00:00:03.000 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/config/transcoding-temp/5C932A/5C932A_%d.ts" 22:11:25.749 ffmpeg version 5.1-emby_2023_06_25 Copyright (c) 2000-2022 the FFmpeg developers and softworkz for Emby LLC 22:11:25.749 built with gcc 10.3.0 (crosstool-NG 1.25.0) 22:11:25.749 Execution Date: 2024-11-14 22:11:25 22:11:25.773 Input #0, matroska,webm, from '/mnt/d/+Tv Shows/Survivor/Season 47/Survivor - S47E06 - Feel the FOMO [MeGusta].mkv': 22:11:25.773 Metadata: 22:11:25.773 ENCODER : Lavf61.5.101 22:11:25.773 Duration: 01:04:28.03, start: 0.000000, bitrate: 5284 kb/s 22:11:25.773 Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], Level 120, 30 fps, 30 tbr, 1k tbn (default) 22:11:25.773 Metadata: 22:11:25.773 BPS : 11523948 22:11:25.773 NUMBER_OF_FRAMES: 116040 22:11:25.773 NUMBER_OF_BYTES : 5571828883 22:11:25.773 ENCODER : Lavc61.11.100 libx265 22:11:25.773 DURATION : 01:04:28.000000000 22:11:25.773 Stream #0:1(eng): Audio: eac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default) 22:11:25.773 Metadata: 22:11:25.773 BPS : 640000 22:11:25.773 NUMBER_OF_FRAMES: 120876 22:11:25.773 NUMBER_OF_BYTES : 309442560 22:11:25.773 DURATION : 01:04:28.032000000 22:11:25.773 Stream #0:2(eng): Subtitle: ass 22:11:25.773 Metadata: 22:11:25.773 title : English (SDH) 22:11:25.773 BPS : 104 22:11:25.773 NUMBER_OF_FRAMES: 1472 22:11:25.773 NUMBER_OF_BYTES : 50360 22:11:25.773 ENCODER : Lavc61.11.100 ssa 22:11:25.773 DURATION : 01:04:20.758000000 22:11:25.775 Stream mapping: 22:11:25.775 Stream #0:0 (hevc) -> format:default (graph 0) 22:11:25.775 format:default (graph 0) -> Stream #0:0 (libx264) 22:11:25.775 Stream #0:1 -> #0:1 (eac3 (native) -> mp3 (libmp3lame)) 22:11:25.775 Press [q] to stop, [?] for help 22:11:25.806 [libx264 @ 0x23b9b00] using SAR=1/1 22:11:25.806 [libx264 @ 0x23b9b00] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 22:11:25.820 [libx264 @ 0x23b9b00] profile High, level 4.0, 4:2:0, 8-bit 22:11:25.859 [libx264 @ 0x23b9b00] 264 - core 163 r3060 5db6aa6 - H.264/MPEG-4 AVC codec - Copyleft 2003-2021 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0 me=hex subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=90 keyint_min=46 scenecut=0 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=3616 vbv_bufsize=7232 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 22:11:25.859 Output #0, segment, to '/config/transcoding-temp/5C932A/5C932A_%d.ts': 22:11:25.859 Metadata: 22:11:25.859 encoder : Lavf59.27.100 22:11:25.859 Stream #0:0: Video: h264, yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 30 fps, 90k tbn 22:11:25.860 Metadata: 22:11:25.860 encoder : Lavc59.37.100 libx264 22:11:25.860 Side data: 22:11:25.860 cpb: bitrate max/min/avg: 3616000/0/0 buffer size: 7232000 vbv_delay: N/A 22:11:25.860 Stream #0:1(eng): Audio: mp3, 48000 Hz, stereo, fltp, 192 kb/s (default) 22:11:25.860 Metadata: 22:11:25.860 encoder : Lavc59.37.100 libmp3lame
Luke 42243 Posted November 17, 2024 Posted November 17, 2024 Hi there @GunbleRhave you compared your nginx configuration to this:
Betonhaus 18 Posted December 19, 2024 Posted December 19, 2024 Do you have a local dns server setup that redirects your domain directly to your server's IP address? If you don't, then devices that access your server are getting your home network's ip address, meaning that all traffic is routed trough your modem to your ISP then back into your home network. or maybe Emby clients are smart enough to figure that out, but the web browser access won't be
