one_sec 0 Posted November 14, 2024 Posted November 14, 2024 Hallo, ich habe das Problem das wenn ich Emby über Synology öffnen möchte nur der Browser das Emby Logo zeigt aber nichts weiter, das Bild ist eingefroren. Ich habe probiert es zu deinstallieren und neu zu installieren , hat leider nichts gebracht. Wenn ich Emby auf dem selben Pc installiere lässt es sich dort öffnen, aber sobald ich dasselbe versuche über Synology geht es nicht. Ich kann nicht mal updaten meine Version ist 4.8.8.0. DS223j DSM 7.2.2-72806
Luke 42239 Posted November 27, 2024 Posted November 27, 2024 Hi @one_seccan you try clearing browsing data and seeing if that helps? Thanks !
Carlo 4561 Posted November 30, 2024 Posted November 30, 2024 I got a PM from him today. This is part of it: Quote I have a problem with emby that I can't solve easily. My system, a DS223J, works and has the latest update. I had to reinstall the system a few times and now I'm having problems with Emby. The software actually works except for the problem that I can no longer update and I can log in to my username to update. I've tried many browsers, almost always with the same result. As soon as I try to update, emby tries to log in to my old user (I created a new account for testing purposes). Your pic shows DSM 7.2.2-72806 Update 1 installed. Us Download the ArmV8 version of Emby Server from https://emby.media/synology-server.html Use Package Manager on the NAS to install this manually. Synology is behind approving our software and getting it listed. So for now you will have to download the file from our site. DSM 7.2x requires a different build of Emby Server than 7.0 or 7.1 . Let us know if this solved your problem of if you have a different problem. Carlo
one_sec 0 Posted November 30, 2024 Author Posted November 30, 2024 Ich habe Arm8 (x18 series) versucht zu installieren und bekomme dieses Antwort " Dieses Paket erfordert DSM 7.2-63134 oder älter" Meine Version ist mittlerweile 7.2.2-72806 Update 2.
one_sec 0 Posted November 30, 2024 Author Posted November 30, 2024 On 11/27/2024 at 5:32 PM, Luke said: Hi @one_seccan you try clearing browsing data and seeing if that helps? Thanks ! i did this but it doesent solved the problem instead i have more problems than before i reinstalled emby after a reset my nas in hope that it will fix the update problem. but now everytime i start a video it will push the cpu on 99% and it lag und stuck in loading process. i bought yesterday premier in hope it will fix my problems but now lost hope that i will fix my prob alone over the forum. thats why i asked carlo for help with remote control.
Luke 42239 Posted December 1, 2024 Posted December 1, 2024 17 hours ago, one_sec said: i did this but it doesent solved the problem instead i have more problems than before i reinstalled emby after a reset my nas in hope that it will fix the update problem. but now everytime i start a video it will push the cpu on 99% and it lag und stuck in loading process. i bought yesterday premier in hope it will fix my problems but now lost hope that i will fix my prob alone over the forum. thats why i asked carlo for help with remote control. @one_sec Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
one_sec 0 Posted December 1, 2024 Author Posted December 1, 2024 from my understanding what happend is after i deleted my old raid and started from scratch, emby wont let me log in my old server which was deleted ofc. But somehow the old server account is still there. The crazy thing is the old one is now updated but if i wanna go on network and set the path for library it show me nothing. i can put 2 logs from 2 different accounts if this helps. these logs 4 are from the first server what i created and this one detected my graphic card. hardware_detection-63868634779.txt embyserver-63868635553.txt hardware_detection-63868635575.txt embyserver.txt
one_sec 0 Posted December 1, 2024 Author Posted December 1, 2024 the new server which i can not update and here he dont get acces to my hardware . you can see on the screenshot a failed attempt login try from my old server account. hardware_detection-63868459283.txt embyserver-63868608000.txt embyserver.txt
Carlo 4561 Posted December 6, 2024 Posted December 6, 2024 (edited) On 12/1/2024 at 1:55 AM, one_sec said: the new server which i can not update and here he dont get acces to my hardware . you can see on the screenshot a failed attempt login try from my old server account. I know you've PMed me but I'm still not sure I understand your issue. You say you can't get access to your hardware. Did you mean you can't access or login to your Emby Server? Failed login attempt by one-sec on Homebox M3UTuner 1.0.33 installed on Hotbox Failed login attempt by harder666 on Hotbox That looks like two different server names: Homebox & Hotbox Did you change your Emby Server name? Did you have two different admin accounts? You pic shows you logged in at the console. If you have an issue with a different account, you can change the password and try logging in again as that user. Let me know what I don't understand or what your problem is. Carlo Edited December 6, 2024 by Carlo
one_sec 0 Posted December 10, 2024 Author Posted December 10, 2024 These are 2 different servers. I created Hotbox back then and used Emby there for the first time. Then I dissolved the RAID because I bought other disks. I then named the new server Homebox. So now we come to the problem that makes me despair. As you can see in the video, he logs into the hotbox account on the very first server all the time. I can also update Emby there, but only if I log in to the dead account. What I mean by that is I can't get rid of this old server no matter what I do. I reset the NAS to factory defaults and the same thing again. I can uninstall emby and reinstall it, also the same problem....
Luke 42239 Posted December 10, 2024 Posted December 10, 2024 3 hours ago, one_sec said: I reset the NAS to factory defaults and the same thing again. Does this leave data on the drive? You should be able to just delete the server data folder if you want to make a fresh start: Emby Server Data Folder
one_sec 0 Posted December 11, 2024 Author Posted December 11, 2024 I deleted the Emby Server log and the Emby Server folder in Windows. This allows the Emby Update to be updated manually on the Synology. THANKS! Now only one thing is missing, as you can see in the picture, my PC hardware could be accessed for coding on the old server account. Why doesn't this work here? AND BIG THX !
one_sec 0 Posted December 11, 2024 Author Posted December 11, 2024 (edited) this is how it looks now hardware_detection-63869485543.txt Edited December 11, 2024 by one_sec
Luke 42239 Posted December 12, 2024 Posted December 12, 2024 @one_secwhat is missing that you are expecting to see? Does your model NAS support any hardware transcoding?
