Ballistic 8 Posted November 18, 2014 Posted November 18, 2014 (edited) Hi All, Thanks alot for those responsible of making the FreeBSD version of Mediabrowser possible. I am moving from a Windows based Mediabrowser to a Freebsd machine today and i noticed that Mediabrowser and Sickbeard seem to have a PID conflict. When running Mediabrowser: ps aux: USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND mediabrowser 66878 145.9 3.2 1006084 797148 ?? S 2:40PM 2:22.26 /usr/local/bin/mono /usr/local/lib/mediabrowser/MediaBrowser.Server.Mono.exe -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/mediabrowser (mono-sgen) and then trying to start Sickbeard: root@storage:/usr/local/sickbeard # /usr/local/etc/rc.d/sickbeard start sickbeard already running? (pid=66877). Debugging: ps aux |grep 66877 root 66877 0.0 0.0 12092 1332 ?? Is 2:40PM 0:00.00 daemon: /usr/local/bin What is this daemon? How can we make sure it does interrupt the startup of other deamons like Sickbeard? Edit: The problem seems to be in the sickbeard init script somewhere. Running Sickbeard manually (python SickBeard.py --daemon) does work fine. Edited November 18, 2014 by Ballistic
josh4trunks 70 Posted November 19, 2014 Posted November 19, 2014 (edited) this is a problem with the rc.d script you are using. daemon is a utility to start+watch processes that can't normally run unattended. as you discovered daemon is not needed. see this link for a proper rc.d script that I maintain. https://github.com/josh4trunks/freenas-plugins/blob/master/ports/multimedia/sickbeard/files/sickbeard.in Edited November 19, 2014 by josh4trunks
Ballistic 8 Posted November 22, 2014 Author Posted November 22, 2014 Thanks you! The init script isn't working unfortunately. "/usr/local/etc/rc.d/sickbeard: ${%...}: Bad substitution" In the script, name has been changed to sickbeard and in rc.conf: sickbeard_enable="YES" sickbeard_user="_sabnzbd" sickbeard_group="sabnzbd" sickbeard_data_dir="/usr/local/sickbeard" I don't run sickbeard from a port. It is installed from GIT.
josh4trunks 70 Posted November 24, 2014 Posted November 24, 2014 you'd need to edit it a bit for your needs. here one that should work without having to edit as much stuff. https://github.com/SiCKRAGETV/SickRage/blob/master/init.freebsd also, there is no official sickbeard port.
