Lessaj 477 Posted November 28, 2024 Posted November 28, 2024 1 hour ago, Losey said: Odd, my NUC is running Windows 11 Pro, not Windows 10. However, that is correct, the NAS is where I have Emby installed. I put the installation in the _backup directory because I was a complete moron when I first installed it. Windows 11 is still basically Windows 10. The version number from MS may be misleading since it starts with 10 but assuredly is Windows 11.
sa2000 689 Posted November 28, 2024 Posted November 28, 2024 2 hours ago, Losey said: Yes, I have Emby running from an RN214 using an Intel NUC NUC8i3BEH Mini PC/HTPC, Intel Dual-Core i3-8109U Upto 3.6GHz, 32GB DDR4, 512GB SSD, WiFi, Bluetooth, Thunderbolt 3, 4k Support, Dual Monitor, connected through ethernet with a Netgear 8-port Router. The NAS is configured in Raid-10 with four 10 TB enterprise hard disk drives, though I plan to upgrade to 20 TB enterprise hard disk drives when I have the finances. I could probably run Emby from the NUC's storage, and run backups onto the NAS, but I couldn't be bothered to figure that out when I first set it up. Absolutely not recommended. sqlite databases on network drive not really on. I don't believe file locking works very well on network drives Suggest you just have the media on the network drive and move the application and its data and transcode temp directory to the host windows computer Otherwise - not a supported environment
Losey 4 Posted December 2, 2024 Author Posted December 2, 2024 Okay, I've reinstalled Emby to run from the NUC's internal storage. It seems to default to the Roaming folder, so I left it at that. After letting it run the usual scans to get everything running and re-enabling my Emby Premiere, I've restored my configuration from backup. The issue of the movie still not displaying all versions on the Losey Home user while the Restricted Tags are used is still occurring. I will upload the logs created when I test it all after it finishes all scheduled tasks and scans.
Solution Luke 42183 Posted December 2, 2024 Solution Posted December 2, 2024 4 minutes ago, Losey said: Okay, I've reinstalled Emby to run from the NUC's internal storage. It seems to default to the Roaming folder, so I left it at that. After letting it run the usual scans to get everything running and re-enabling my Emby Premiere, I've restored my configuration from backup. The issue of the movie still not displaying all versions on the Losey Home user while the Restricted Tags are used is still occurring. I will upload the logs created when I test it all after it finishes all scheduled tasks and scans. Hi there is an issue in 4.8 related to the combination of multiple versions and tag restrictions. It has been resolved in the 4.9 beta channel if you need immediate relief. Thanks. 1
