Asazen 8 Posted November 19, 2024 Author Posted November 19, 2024 (edited) Thank you all for checking, hopefully you can fix it. I don't understand programming, but is it very complicated to make emby use BDinfo to extract audio and subtitle information? It would just be a matter of reading the information, it doesn't even need to get the bitrate. Edited November 19, 2024 by Asazen
Carlo 4561 Posted November 19, 2024 Posted November 19, 2024 I don't have any BDMV to test with. @Happy2PlayTry the 3rd command again but leave everything off after language. Doubt it will make a difference, but curious. ffprobe -i "E:\Media\Movies - nfo\Beetlejuice.Beetlejuice.2024.MULTi.COMPLETE.BLURAY\BDMV\PLAYLIST\00800.mpls" -show_entries stream_tags=language @LukeThat's interesting as Happy2Play posted the results he got running BDInfo on his BDMV and the language of tracks showed up. I wonder what may be different using the exe vs the library?
Happy2Play 9811 Posted November 19, 2024 Posted November 19, 2024 4 minutes ago, Carlo said: I don't have any BDMV to test with. @Happy2PlayTry the 3rd command again but leave everything off after language. Doubt it will make a difference, but curious. ffprobe -i "E:\Media\Movies - nfo\Beetlejuice.Beetlejuice.2024.MULTi.COMPLETE.BLURAY\BDMV\PLAYLIST\00800.mpls" -show_entries stream_tags=language @LukeThat's interesting as Happy2Play posted the results he got running BDInfo on his BDMV and the language of tracks showed up. I wonder what may be different using the exe vs the library? ffmpeg/ffprobe just can't read the information correctly. But couldn't get anything targeting the mpls. C:\Users\Media>C:\Users\Media\AppData\Roaming\Emby-Server\system\ffprobe.exe -i "bluray:E:\\Media\Movies - nfo\\Beetleju ice.Beetlejuice.2024.MULTi.COMPLETE.BLURAY" ffprobe version 5.1-emby_2023_06_25 Copyright (c) 2007-2022 the FFmpeg developers and softworkz for Emby LLC built with gcc 12.2.0 (Rev10, Built by MSYS2 project) ../src/libbluray/bdj/bdj.c:614: libbluray-j2se-1.3.4.jar not found. ../src/libbluray/bdj/bdj.c:801: BD-J check: Failed to load libbluray.jar ../src/libbluray/bdj/bdj.c:614: libbluray-j2se-1.3.4.jar not found. ../src/libbluray/bdj/bdj.c:801: BD-J check: Failed to load libbluray.jar [bluray @ 000002b435092bc0] 9 usable playlists: [bluray @ 000002b435092bc0] playlist 00055.mpls (0:05:40) [bluray @ 000002b435092bc0] playlist 00300.mpls (0:27:37) [bluray @ 000002b435092bc0] playlist 00301.mpls (0:08:34) [bluray @ 000002b435092bc0] playlist 00302.mpls (0:06:52) [bluray @ 000002b435092bc0] playlist 00303.mpls (0:06:26) [bluray @ 000002b435092bc0] playlist 00304.mpls (0:09:14) [bluray @ 000002b435092bc0] playlist 00305.mpls (0:12:07) [bluray @ 000002b435092bc0] playlist 00306.mpls (0:07:54) [bluray @ 000002b435092bc0] playlist 00800.mpls (1:44:40) [bluray @ 000002b435092bc0] selected 00800.mpls [mpegts @ 000002b4350924c0] start time for stream 9 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 10 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 11 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 12 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 13 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 14 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 15 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 16 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 17 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 18 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 19 is not set in estimate_timings_from_pts [mpegts @ 000002b4350924c0] start time for stream 20 is not set in estimate_timings_from_pts ../src/libbluray/bluray.c:299: 01156.m2ts: no timestamp for SPN 0 (got 0). clip 524280-283168516. [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 9 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 10 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 11 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 12 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 13 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 14 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 15 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 16 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 17 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 18 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 19 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [mpegts @ 000002b4350924c0] Could not find codec parameters for stream 20 (Subtitle: hdmv_pgs_subtitle (pgssub) ([144][0][0][0] / 0x0090)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options Input #0, mpegts, from 'bluray:E:\\Media\Movies - nfo\\Beetlejuice.Beetlejuice.2024.MULTi.COMPLETE.BLURAY': Duration: 01:44:40.86, start: 11.650667, bitrate: 41894 kb/s Program 1 Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], Level 41, 23.98 fps, 23.98 tbr, 90k tbn, Start-Time 11.651s Stream #0:1[0x1100]: Audio: truehd (AC-3 / 0x332D4341), 48000 Hz, 7.1, s32 (24 bit), Start-Time 11.651s Stream #0:2[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 448 kb/s, Start-Time 11.651s Stream #0:3[0x1101]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 640 kb/s, Start-Time 11.651s Stream #0:4[0x1102]: Audio: truehd (AC-3 / 0x332D4341), 48000 Hz, 7.1, s32 (24 bit), Start-Time 11.651s Stream #0:5[0x1102]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, 5.1(side), fltp, 448 kb/s, Start-Time 11.651s Stream #0:6[0x1103]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s, Start-Time 11.651s Stream #0:7[0x1104]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, 5.1(side), s32p (24 bit), Start-Time 11.651s Stream #0:8[0x1105]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s, Start-Time 11.651s Stream #0:9[0x1200]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:10[0x1201]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:11[0x1202]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:12[0x1203]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:13[0x1204]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:14[0x1205]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:15[0x1206]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:16[0x1207]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:17[0x1208]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:18[0x1209]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:19[0x120a]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s Stream #0:20[0x120b]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090), Start-Time 11.651s 1
Asazen 8 Posted November 20, 2024 Author Posted November 20, 2024 (edited) and you can't use BDinfo directly, which is precisely what it's for? I was testing yesterday and in Kodi and Plex it shows the audio tags and subtitles of BDMV structures perfectly, I imagine they use BDinfo. @Happy2Play Thank you very much for the tests you are carrying out. Edited November 20, 2024 by Asazen
Carlo 4561 Posted November 20, 2024 Posted November 20, 2024 @Happy2PlayAppreciate you trying that for me!
Carlo 4561 Posted November 20, 2024 Posted November 20, 2024 Does anyone know if the information for tacks in the media file is available to modify via Emby's API?
Luke 42241 Posted November 21, 2024 Posted November 21, 2024 12 hours ago, Asazen said: and you can't use BDinfo directly, which is precisely what it's for? I was testing yesterday and in Kodi and Plex it shows the audio tags and subtitles of BDMV structures perfectly, I imagine they use BDinfo. @Happy2Play Thank you very much for the tests you are carrying out. We do use BdInfo, and normally for most titles it is able to find the languages.
Asazen 8 Posted November 21, 2024 Author Posted November 21, 2024 2 hours ago, Luke said: We do use BdInfo, and normally for most titles it is able to find the languages. I have about 300 titles in BDMV format and in none of them do I detect the language tags.
Luke 42241 Posted December 10, 2024 Posted December 10, 2024 OK please try refreshing the metadata on one of these and then attach the emby server log. Thanks. 1
