Bucko 3 Posted November 8, 2024 Posted November 8, 2024 I run Emby on my DS223j Nas and a Win 11 PC. Emby reports my server needs updating from 8.0 to 10. It instructs me to download the update (which I did) emby-server-synology72_4.8.10.0_x86_64.spk Now it tells me to stop the server. After I stop the server, how do I update Emby on my NAS??? The update file does not open saying to pick a program to open it. I spend 2 hours searching for a simple procedure explaining how I update the Emby server! Is this some secret operation? Why is there no help on the steps I do to simply update my server? Any help would be appreciated.
Luke 42234 Posted November 10, 2024 Posted November 10, 2024 Hi, it will take time to get through the Synology review process. If you want to upgrade immediately you can always download the spk from our website. Thanks.
Bucko 3 Posted November 10, 2024 Author Posted November 10, 2024 So I guess what you are saying is that although Emby notified me of an update, it does not really apply to my synology version as yet. Once it does, then synology will preform the update without me doing much more than clicking the update button. Correct? I already dl the spk thinking this was the way I needed to do it. But because I could not use this file, it is what prompted me to ask here what to do.
Luke 42234 Posted November 17, 2024 Posted November 17, 2024 Quote So I guess what you are saying is that although Emby notified me of an update, it does not really apply to my synology version as yet. It's not hooked into package center. It's notifying you that there is a new version available on our website. Quote Once it does, then synology will preform the update without me doing much more than clicking the update button. Correct? Correct. The normal update process for updating any app through Synology package center.
