Afaflix 1 Posted November 7, 2024 Posted November 7, 2024 As it is right now, curating a 'permitted catalog' is cumbersome at best. The rating system helps but is imperfect. I would like to see a way of quickly scanning through the permitted and/or existing catalog and block/allow any movie with a single click for a particular account. I imagine a login from within that account to unlock this feature
Luke 42245 Posted November 11, 2024 Posted November 11, 2024 HI, yes it makes sense. Have you also tried using tags?
Afaflix 1 Posted November 11, 2024 Author Posted November 11, 2024 27 minutes ago, Luke said: HI, yes it makes sense. Have you also tried using tags? Oh yes. It works but 'right click - select edit metadata - scroll down - click Add Tag - type tag that works great if the collection is 20 movies large I imagine the admin to create an account for the child, then you log into that account and within that account you can enter a 'parent-mode'. Now you see the whole of the catalog again and you can simply check or uncheck movies to be available. similar to the 'Mark Played' check-box and it's visibility in the 'Latest Movies' section. Like this the parent doesn't have to have admin access Thank you for reading 1
