As777 27 Posted November 6, 2024 Posted November 6, 2024 I am having trouble with passthrough on Nvidia Shield Pro to my LG C3 TV.. It used to work perfectly but the last week or so only "stereo" is being sent to my receiver. There is no transcoding going on as it says under Stats for Nerds that the audio is full surround quality. I am always using the latest beta of the server and i regularly update the Android mobile app on the Shield (I dont use the Android TV version). It definitely seems to be an Emby issue because other programs are passing through without any issue (Kodi for instance).
Luke 42242 Posted November 6, 2024 Posted November 6, 2024 12 minutes ago, As777 said: I am having trouble with passthrough on Nvidia Shield Pro to my LG C3 TV.. It used to work perfectly but the last week or so only "stereo" is being sent to my receiver. There is no transcoding going on as it says under Stats for Nerds that the audio is full surround quality. I am always using the latest beta of the server and i regularly update the Android mobile app on the Shield (I dont use the Android TV version). It definitely seems to be an Emby issue because other programs are passing through without any issue (Kodi for instance). Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
As777 27 Posted November 11, 2024 Author Posted November 11, 2024 The issue seems to be a problem between my Shield Pro, LG C3 TV, and Denon receiver and presumably the Exo player or whatever it is called that Emby uses for media playback. Emby stats for nerds shows that it is not transcoding anything and is playing back the stream. I am having so many issues with my set up (non Emby related) that I am constantly changing between the receiver HDMI ports and TVs HDMI ports to try and get some stability. The LG C3 often reports "No Signal" when turning the TV on. Obviously, this is not an Emby fault. Another issue is that sometimes I lose audio completely across all Shield apps until I reboot it. However, since Kodi is working on the Shield and will passthrough correctly this is probably a software issue somewhere down the line with Android. Am i right in thinking Kodi has its own code for the player and passthrough? The only thing different about my system that has changed in the last few weeks was a new update to the LG C3 so maybe something is screwed there.
Luke 42242 Posted November 16, 2024 Posted November 16, 2024 @As777Can we please look at a specific example?
