johnnychillout 0 Posted December 12, 2024 Author Posted December 12, 2024 I removed that scripterx plugin weeks ago, that didn’t fix the issue
Luke 42289 Posted December 12, 2024 Posted December 12, 2024 14 minutes ago, johnnychillout said: I removed that scripterx plugin weeks ago, that didn’t fix the issue Are you sure? It's in your log that you provided four days ago.
johnnychillout 0 Posted December 13, 2024 Author Posted December 13, 2024 Yes, I created a new playlist, scan the library and it deleted my playlist. How do we fix this? What’s strange is this started happening a a couple months ago, it was fine before that i removed the scripterx a month ago
Happy2Play 9814 Posted December 13, 2024 Posted December 13, 2024 2 minutes ago, johnnychillout said: Yes, I created a new playlist, scan the library and it deleted my playlist. How do we fix this? What’s strange is this started happening a a couple months ago, it was fine before that i removed the scripterx a month ago This will become why is only your system doing it and how do we reproduce it? Are the user created playlist m3u files in C:\Users\username\AppData\Roaming\Emby-Server\programdata\data\userplaylists folder empty?
Happy2Play 9814 Posted December 13, 2024 Posted December 13, 2024 I guess another test would be can you create a new user and create a playlist and see if the same thing happens?
johnnychillout 0 Posted December 13, 2024 Author Posted December 13, 2024 yes, the folders are out there but the only file the only thing in the folders is the one m3u file
johnnychillout 0 Posted December 13, 2024 Author Posted December 13, 2024 and i created a new playlist using a different profile. ran the library scan, and playlists disappeared
johnnychillout 0 Posted December 13, 2024 Author Posted December 13, 2024 i deleted the scan media library scan trigger (it was running every 12 hours). not sure if that will fix it
Luke 42289 Posted December 13, 2024 Posted December 13, 2024 1 minute ago, johnnychillout said: i deleted the scan media library scan trigger (it was running every 12 hours). not sure if that will fix it I wouldn't really consider that a fix but rather if this is associated with the library scan then we should get to the bottom of that.
Luke 42289 Posted December 13, 2024 Posted December 13, 2024 5 minutes ago, johnnychillout said: and i created a new playlist using a different profile. ran the library scan, and playlists disappeared OK please attach the emby server log from that time period. Thanks.
Happy2Play 9814 Posted December 13, 2024 Posted December 13, 2024 Since you are on Windows I would spin up a portable install, change Emby ports, and create a test library and see if the same happens. I have not been able to create a playlist and have it just disappear or come back empty. But if Emby is actual doing this it should be in the server log. 1
johnnychillout 0 Posted December 13, 2024 Author Posted December 13, 2024 here is the last log embyserver (3).txt
Happy2Play 9814 Posted December 13, 2024 Posted December 13, 2024 Dev may see something but I am not. Not sure if Debug logging will provide any more info. Line 770: 2024-12-13 10:06:22.130 Info Server: http/1.1 POST http://localhost:8096/emby/Playlists?Name=test 12-13-24&Ids=20781,20355,20326,20790,19957,20837&userId=89bd38986398499b91cca8171a10a14d&X-Emby-Client=Emby Web&X-Emby-Device-Name=Microsoft Edge Windows&X-Emby-Device-Id=97c95532-13f8-4599-b206-6732902a1dd9&X-Emby-Client-Version=4.8.10.0&X-Emby-Token=x_secret1_x&X-Emby-Language=en-us. Source Ip: ::1, UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/131.0.0.0 Safari/537.36 Edg/131.0.0.0 Line 771: 2024-12-13 10:06:22.699 Info PlaylistManager: Playlist test 12-13-24 is initially created with 6 items Line 772: 2024-12-13 10:06:22.702 Info PlaylistManager: Adding 6 items to playlist test 12-13-24. skipDuplicates: False Line 773: 2024-12-13 10:06:22.726 Info App: Added 6 items to playlist test 12-13-24. skipDuplicates: False Line 774: 2024-12-13 10:06:22.728 Info Server: http/1.1 Response 200 to ::1. Time: 598ms. POST http://localhost:8096/emby/Playlists?Name=test 12-13-24&Ids=20781,20355,20326,20790,19957,20837&userId=89bd38986398499b91cca8171a10a14d&X-Emby-Client=Emby Web&X-Emby-Device-Name=Microsoft Edge Windows&X-Emby-Device-Id=97c95532-13f8-4599-b206-6732902a1dd9&X-Emby-Client-Version=4.8.10.0&X-Emby-Token=x_secret1_x&X-Emby-Language=en-us 2024-12-13 10:07:03.928 Info TaskManager: Executing Scan media library 2024-12-13 10:07:03.928 Info Server: http/1.1 Response 204 to ::1. Time: 2ms. POST http://localhost:8096/emby/ScheduledTasks/Running/6330ee8fb4a957f33981f89aa78b030f?X-Emby-Client=Emby Web&X-Emby-Device-Name=Microsoft Edge Windows&X-Emby-Device-Id=97c95532-13f8-4599-b206-6732902a1dd9&X-Emby-Client-Version=4.8.10.0&X-Emby-Token=x_secret1_x&X-Emby-Language=en-us Line 785: 2024-12-13 10:07:35.780 Info App: Removing item from database, Type: Folder, Name: test 12-13-24 [playlist], Path: C:\Users\John Allholm\AppData\Roaming\Emby-Server\programdata\data\userplaylists\test 12-13-24 [playlist], Id: 288595
johnnychillout 0 Posted December 14, 2024 Author Posted December 14, 2024 Hopefully, they can. It’s still occurring
Happy2Play 9814 Posted December 14, 2024 Posted December 14, 2024 3 hours ago, johnnychillout said: Hopefully, they can. It’s still occurring Have you tried spinning up a portable and retesting?
Happy2Play 9814 Posted December 14, 2024 Posted December 14, 2024 20 minutes ago, johnnychillout said: How do I set up a portable Download the portable extact to any folder you like and launch the exe. Emby Server for Windows Note by default Emby always installs using the same ports so you will want to shutdown existing temporarily and launch new install and ensure to change ports on the network page. Then both can run simultaneously. I would just setup a test library but if you run both you don't want both writing metadata as you will put each in a scan loop as then both see and do updates.
Luke 42289 Posted December 19, 2024 Posted December 19, 2024 @johnnychilloutwere you able to try this?
