bryan_remote 7 Posted October 29, 2024 Posted October 29, 2024 How do I restore Emby default m3u tuner? in my early days, I installed iptv plugin, but getting some issues. was reading that emby has default m3u but when I add, it only shows Hauppage and Homerun as sources?
bryan_remote 7 Posted October 29, 2024 Author Posted October 29, 2024 How do I restore Emby default m3u tuner? in my early days, I installed iptv plugin, but getting some issues. so I was reading that emby has default m3u tuner but when I add, it only shows Hauppage and Homerun as sources? please forgive any terminology mistakes..
bryan_remote 7 Posted October 29, 2024 Author Posted October 29, 2024 I added the m3u plugin and it seems that fixed it. Unless you say different, I will assume this a correct remedy 1
Luke 42241 Posted October 29, 2024 Posted October 29, 2024 Hi @bryan_remotewhat do you mean by this exactly? What did you remove that needs restoring?
bryan_remote 7 Posted October 29, 2024 Author Posted October 29, 2024 i was having some issues with live channels, and thought I was using a plugin versus what was part of emby server out the box. I also had iptv plugin installed. I removed m3u tv tuner and iptv plugin. i have since reinstalled m3u plugin and I am back in business. Is the m3u plugin part of the out of box emby server?
bryan_remote 7 Posted October 29, 2024 Author Posted October 29, 2024 on a clean server install, is the m3u plugin already installed by default? And what other Plugins are installed in a fresh Emby server install?
Solution Luke 42241 Posted October 29, 2024 Solution Posted October 29, 2024 4 minutes ago, bryan_remote said: on a clean server install, is the m3u plugin already installed by default? And what other Plugins are installed in a fresh Emby server install? Yes it is, so if you're having to reinstalled it then it means you must have removed it at some point and then forgot that you did that.
