curation 0 Posted October 28, 2024 Posted October 28, 2024 Anyone know if is there a default setting for the title suggestions that come up after watching a particular title? And can it be edited?
Luke 42245 Posted October 29, 2024 Posted October 29, 2024 HI, what exactly do you mean by title suggestions?
curation 0 Posted October 29, 2024 Author Posted October 29, 2024 (edited) Such as, in this case, it appears that the default "more like this" seemed to be determined by relative date. Edited October 29, 2024 by curation
Happy2Play 9812 Posted October 29, 2024 Posted October 29, 2024 There is no user config for the conditions that populate the More Like this/Because you Watched this sections. Believe it matches by genre and possibly rating but a dev would have to confirm but has been mentioned in other topics.
curation 0 Posted October 29, 2024 Author Posted October 29, 2024 Thanks! Unsuccessfully checked other topics, hopefully a dev can confirm.
Happy2Play 9812 Posted October 29, 2024 Posted October 29, 2024 I know genre is the primary factor But not positive on other factors.
Luke 42245 Posted October 31, 2024 Posted October 31, 2024 On 10/28/2024 at 8:30 PM, curation said: Such as, in this case, it appears that the default "more like this" seemed to be determined by relative date. Relative date? It's based on finding similar titles to the one you're looking at by comparing metadata. Nothing to do with date.
curation 0 Posted November 1, 2024 Author Posted November 1, 2024 (edited) So the method is: metadata entry & edit. Yes? Edited November 1, 2024 by curation
Luke 42245 Posted November 3, 2024 Posted November 3, 2024 On 11/1/2024 at 6:11 PM, curation said: So the method is: metadata entry & edit. Yes? Hi, can you please describe what exactly you're asking? Method of what? To do what?
