mudbaby 4 Posted October 28, 2024 Posted October 28, 2024 Hello Everyone I have setup my server and have added my M3U and EPG files in Emby Server. When watching a channel everything works great until i recording i have scheduled starts and then I start getting freezing and the spinning wheel of no return. If anyone can suggest what could be the issues. Server Spec's Hardware: DL360 Gen 8 Intel Xeon CPU E5-2643 v2 @ 3.50 GHZ 12 cores @ 2, 356 GB Ram. OS windows server 2019 Desktop on 960 SSD, Thanks
Gilgamesh_48 1244 Posted October 28, 2024 Posted October 28, 2024 Server version? Client being used? Log files???? Without those little help can be offered.
mudbaby 4 Posted October 28, 2024 Author Posted October 28, 2024 (edited) Emby server version is 4.8.10.0 Client is the version 1.0.44 available on LG TV. Hopefully that is the log file you need if not let me know. embyserver.txt Edited October 28, 2024 by mudbaby
Carlo 4561 Posted November 2, 2024 Posted November 2, 2024 I didn't see anything in your log file that shows anything similar to the issue you described. Can you try and reproduce the issue, then upload the logs after. Thanks, Carlo
