Adam Pessach 2 Posted October 26, 2024 Posted October 26, 2024 Hello again, I wanted to discuss this time about 2 subjects. (1) I noticed that chapter markings and preview thumbnails are affected by video format. If the video is in 4:3 format the preview thumbnail and chapter markings will be in similar proportions. However, when the video aspect ratio is that of a widescreen the thumbnails and chapter markings bear black borders although the file is cropped. I know there are many different widescreen aspect ratios and that the current way is probably easier to make, but I do think that it will vastly improve the app and be useful. (2) I noticed in movies that in the metadata you can manually edit in different type of 3D formats and a 3D icon will pop up next to the movie's genre. I was hoping you could add in future app versions a similar icon for example Dolby Atmos, HDR content etc. I'm attaching images for illustration. Thank you for your help and time!
Luke 42245 Posted October 28, 2024 Posted October 28, 2024 Quote I noticed that chapter markings and preview thumbnails are affected by video format. If the video is in 4:3 format the preview thumbnail and chapter markings will be in similar proportions. However, when the video aspect ratio is that of a widescreen the thumbnails and chapter markings bear black borders although the file is cropped. I know there are many different widescreen aspect ratios and that the current way is probably easier to make, but I do think that it will vastly improve the app and be useful. Hi, the thumbnails reflect what is in the video, right?
Luke 42245 Posted October 28, 2024 Posted October 28, 2024 Quote I noticed in movies that in the metadata you can manually edit in different type of 3D formats and a 3D icon will pop up next to the movie's genre. I was hoping you could add in future app versions a similar icon for example Dolby Atmos, HDR content etc. I'm attaching images for illustration. Hi ,yes this will be coming. Thanks ! 1
Adam Pessach 2 Posted November 16, 2024 Author Posted November 16, 2024 Hi, as I've explained the thumbnails of both chapter markings and live preview have those black borders. The thumbnails reflect what's in the video, yes.
Luke 42245 Posted November 17, 2024 Posted November 17, 2024 OK can you show a screenshot example from Emby to demonstrate the issue that you're trying to convey? Thanks !
Luke 42245 Posted November 17, 2024 Posted November 17, 2024 OK that's just because the box that it gets displayed in has a 16:9 aspect ratio. We have a few aspects that get used, for example 16:9, 4:3, etc. You don't see bars on the 4:3 one just because it happens to be an exact match.
Adam Pessach 2 Posted November 17, 2024 Author Posted November 17, 2024 Yes, I know that since it is a 2.4:1 aspect ratio, black borders are added to the thumbnails. I was just wondering if you could, in future app updates, support all possible aspect ratios. I saw that in several streaming services even ultra-wide screen aspect ratio gets supported without that addition of those borders. I don't think there is necessarily an issue with the way it looks at the moment, but it can improve the app's interface, in my opinion. Thank you anyway for your support.
Luke 42245 Posted November 17, 2024 Posted November 17, 2024 Hi, yes we can look at improving it for 2.40:1. Thanks for the feedback.
