jmariani 24 Posted March 19, 2025 Author Posted March 19, 2025 3 hours ago, Neminem said: That would suggest permissions issues Log file was updating correctly until the three instances happens. After that, log stops updating, like none of the instances are writing to it.
sa2000 695 Posted April 3, 2025 Posted April 3, 2025 On 30/03/2025 at 22:34, jmariani said: Most of the time. Are you able to predict when it is going to happen to reproduce the issue. If you are, you could run Microsoft SysInternals Process Monitor before it is going to happen and then stop the capture when you see the multiple instances. ProcMon is heavy on using system resources - so would need to only run for max of 20 / 30 minutes and to predict it is going to arise within that period. If you know how to bring it about - the a zipped procmon PML plus a zip of a copy of the Emby Server logs folder would be good to have Have you established that the issue is to do with the PC going to sleep and gets woken up for scheduled recordings?
jmariani 24 Posted April 4, 2025 Author Posted April 4, 2025 No, it's totally random. Also, I'm running macOS, not windows. The issue has nothing to do with machine going to sleep.
