Hispanico957 23 Posted October 25, 2024 Posted October 25, 2024 On my aNvidia Shield Pro I noticed that the android app while I type the name for the search already suggests the movies in the background depending on the letters typed, the android tv app does not propose them and does it only at the end giving the search action, which is less direct and easy Thank Hispa
seanbuff 1356 Posted October 25, 2024 Posted October 25, 2024 10 minutes ago, Hispanico957 said: On my aNvidia Shield Pro I noticed that the android app Are you happy to continue using the universal Android app? 4
Hispanico957 23 Posted October 25, 2024 Author Posted October 25, 2024 (edited) 1 hour ago, seanbuff said: Are you happy to continue using the universal Android app? Sure I'm satisfied with the native android app, but on an android tv I would prefer to use the dedicated one. And also because then I don't understand why make 2 versions Hispa Edited October 25, 2024 by Hispanico957
Solution CBers 7554 Posted October 25, 2024 Solution Posted October 25, 2024 11 minutes ago, Hispanico957 said: And also because then I don't understand why make 2 versions The Android TV app will be discontinued at some point in the future, so all development is being put into the Universal Android app. The Android TV app is only receiving bug fixes. 1 1
justinrh 267 Posted October 25, 2024 Posted October 25, 2024 15 hours ago, CBers said: some point in the future At this rate it won't be in the future of my lifetime, it seems.
