y3knik 17 Posted October 25, 2024 Posted October 25, 2024 Hello, I have tried 3 different providers and its the same each time. This has been working for years and I believe stopped working with the latest stable release. I have an m3u URL and an EPG URL entered. When I hit refresh, the channels come in but the programs wont populate. At first I thought it was my provider so I got a new one and the same issue happened with them too. I am running the latest docker image. The logs show the following for all channels. My logs have my credentials so I can share them privately if needed.
Solution Carlo 4560 Posted October 25, 2024 Solution Posted October 25, 2024 @y3knikHi, Looking at the errors above it appears to be having problems loading the XML guide data. You could try downloading the XML file manually, saving it to disk. Then change the XML guide location in Emby to read the file. Then refresh. That will help determine if there's a download issue or if Emby has a problem with the file itself. If you want to PM me your M3U and XML info for one or both providers, I can spin up a test machine to figure out what's going on for you. Carlo
y3knik 17 Posted November 1, 2024 Author Posted November 1, 2024 Thanks for the help! Wasn't an emby issue afterall! 1 2
