Thidsa 44 Posted January 15, 2025 Author Posted January 15, 2025 (edited) No, sorry. All that i have left is to blame the IOS app. I dont understand how all other devices (web, android app, androidtv, appletv, new windows/xbox app, sorry for repeating ) works remotely and not the ios app. And when @Lessajsaid it works for him, im kinda lost. It used to work for years....until 2.2.31 Edited January 15, 2025 by Thidsa
Thidsa 44 Posted February 12, 2025 Author Posted February 12, 2025 On 2/7/2025 at 8:53 PM, Luke said: Hi, can you try connecting again? Connecting with https://my.domain.com trough reverse proxy (like i do with all my other emby apps) still dont work Connecting with http://my.dyndns.com to specific opened port do work
visproduction 335 Posted February 12, 2025 Posted February 12, 2025 Possibly related? https://duckduckgo.com/?q=connect+reverse+proxy+error+fails&ia=web
Thidsa 44 Posted February 15, 2025 Author Posted February 15, 2025 I dont see how. As I have said a couple posts up all other emby apps I use works with the rev proxy
pwhodges 2033 Posted February 15, 2025 Posted February 15, 2025 The iOS app works fine with reverse proxies for countless other people; there just has to be something about either your iOS settings or your reverse proxy that is slightly odd. At this stage I would suggest you look at the logs of your reverse proxy to see what is happening when the app tries to connect to your IP address. Paul 1
Luke 42240 Posted February 16, 2025 Posted February 16, 2025 9 hours ago, pwhodges said: At this stage I would suggest you look at the logs of your reverse proxy to see what is happening when the app tries to connect to your IP address. Yes this is a great idea. Thanks.
Thidsa 44 Posted February 16, 2025 Author Posted February 16, 2025 On 2/15/2025 at 7:46 PM, pwhodges said: The iOS app works fine with reverse proxies for countless other people; there just has to be something about either your iOS settings or your reverse proxy that is slightly odd. At this stage I would suggest you look at the logs of your reverse proxy to see what is happening when the app tries to connect to your IP address. Paul Heh yes. Finally it works now Was some CORS setting that needed a change. Didint know about it 3 1
Luke 42240 Posted February 17, 2025 Posted February 17, 2025 3 hours ago, Thidsa said: Heh yes. Finally it works now Was some CORS setting that needed a change. Didint know about it hi, what was the setting?
Thidsa 44 Posted February 17, 2025 Author Posted February 17, 2025 1 hour ago, Luke said: hi, what was the setting? CORS Origin, default was empty. Needed to set it to * 1
