Pilaf 0 Posted October 23, 2024 Posted October 23, 2024 Hi, I cant play some media. I get an error message like there is no compatible flux (on PC and TV). On mobile i dont get error but its too slow i get 2-3 seconds of images and then infinite load. Emby version : 4.8.10.0 (last available) via manual installation with emby-server-qnap_4.8.10.0_x86_64.qpkg Here is the last ffmeg log (i played from my PC) : ffmpeg-transcode-fd9d1b50-b8fc-41cb-b0df-a7c0054dd38d_1.txt It happens only with big media, it sounds its a conversion problem ? On my TV im conected with ethernet cat 6 cable, 1Gb available. 4K flux is 200Mb, why does i cant direct play without conversion ? I give you also the embyserver.txt log : embyserver.txt Thank you in advance and sorry for bad english
GrimReaper 4894 Posted October 23, 2024 Posted October 23, 2024 (edited) Quote &TranscodeReasons=SubtitleCodecNotSupported,DirectPlayError&allowVideoStreamCopy=false&allowAudioStreamCopy=false Try playing that item without graphical (PGSSUB) subs selected (choose either embedded text subs (SUBRIP) or obtain external text-based subs (SRT)). Edited October 23, 2024 by GrimReaper
Neminem 1620 Posted October 23, 2024 Posted October 23, 2024 (edited) Your Server is not fast enough to transcode your video file. 10:31:26.199 elapsed=00:00:01.93 frame= 13 fps=6.7 q=0.0 size=N/A time=00:00:00.50 bitrate=N/A throttle=off speed=0.261x The number marked in RED should be over 1 for you to stream that file. It looks like you are using Chrome as your player. Thats not great with HVEC and you have selected TrueHD 7.1 audio + subs. Thats too much for you CPU VAAPI Atom Processor Z36xxx/Z37xxx Series Graphics Edited October 23, 2024 by Neminem
Pilaf 0 Posted October 23, 2024 Author Posted October 23, 2024 (edited) My log IS from Chrome but its the same with emby client. Regarding to my CPU, Can I make something to avoid transcoding? Like direct output and let the client manage ? It seems that i could play 4K médias in the past but not sure about the size. PS : i have an old nvidia shield should i use it as emby server ? Edited October 23, 2024 by Pilaf
Neminem 1620 Posted October 23, 2024 Posted October 23, 2024 What client ? Your supplied transcode log shows this. App: Emby Web 4.8.10.0 Chrome Windows User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/130.0.0.0 Safari/537.36 You could try disabling these for your user. Other wise stay away from 4K until you get a client or server that handle that.
Pilaf 0 Posted October 23, 2024 Author Posted October 23, 2024 (edited) Because i gave you a log from chrome client like i said it dont work too.with emby client for Android and LG OS smart TV. Do you think an old NVIDIA Shield (2015) Can handle it ? Tegra X1, huit cœurs : 4 Cortex A57 à 2 Ghz et 4 Cortex A53 Edited October 23, 2024 by Pilaf
Luke 42238 Posted October 23, 2024 Posted October 23, 2024 Hi, are you saying you want to use the shield as a client? Yes that is a great choice.
