Jay1911 7 Posted October 21, 2024 Posted October 21, 2024 I've been having some of my users reach their streaming limit of 2 when they only have 2 devices. This has been happening to the same two users and both of them have a Roku TV as one of their devices so the Roku may or may not be related. The particular user I've been trying to help tonight has a Roku TV and an Amazon Firestick and their account is set to a maximum of 2 streams, so it should not be possible for them to receive the "Your account has exceeded the maximum streaming limit set by the administrator" error. I've attached a server log. The user told me that they are able to watch livetv but when trying to play some shows, they were getting the maximum streaming limit error. There is a connection from their firestick that doesn't seem to want to go away. It shows them as having a paused livetv connection from their firetv but they are not using the firetv and the emby app is not open on their firetv. I am not able to "stop" the connection from my end. I've had another user with a Roku TV tell me similar situations where they say they can stream livetv but they can't stream anything from TV Shows without getting the error. embyserver(38).txt
Jay1911 7 Posted October 21, 2024 Author Posted October 21, 2024 (edited) Just a quick update that I noticed. I was watching the dashboard and I noticed that their connection from the Roku is flashing back and forth between two different LiveTV Channels on the same device which is not possible so my guess is that Emby thinks there is two connections from that same device and then also the hung up connection from the FireTV which is why theyre getting the maximum connections error when they only have 2 devices.... Updated log attached embyserver(39).txt Edited October 21, 2024 by Jay1911
Neminem 1623 Posted October 21, 2024 Posted October 21, 2024 Known issue, dev's are looking into it. Restart of Emby server should clear out stuck streams. 1
Jay1911 7 Posted October 21, 2024 Author Posted October 21, 2024 (edited) 3 minutes ago, Neminem said: Known issue, dev's are looking into it. Restart of Emby server should clear out stuck streams. Thank you brother, just glad its not a problem on my end. Seems crazy that they said they are aware and have a solution 7 months ago, no? Edited October 21, 2024 by Jay1911
Carlo 4561 Posted October 21, 2024 Posted October 21, 2024 Try this. Ask the user to stop playing the stream as opposed to backing out of playing and see if that makes a difference. 2
Jay1911 7 Posted October 21, 2024 Author Posted October 21, 2024 4 hours ago, Carlo said: Try this. Ask the user to stop playing the stream as opposed to backing out of playing and see if that makes a difference. Will try that thank you
Jay1911 7 Posted October 23, 2024 Author Posted October 23, 2024 18 minutes ago, Luke said: @Jay1911 has this helped? Won't know for sure for a while, it only happens once every few weeks but it's something that has been happening periodically for several months, if not since the very start of Roku devices accessing my server I just haven't reported the issue until now. 1
