richenginner 2 Posted October 20, 2024 Posted October 20, 2024 Hello, Since before version 4.8.1.0 you could enter the manual section of HOST: domain.com directly PORT: XXX I made the mistake of updating the server to version 4.8.8.8 and now it forces me to put: HOST: http://domain.com PS. My domain has an insecure connection If I don't put the http:// I get an error when connecting to the server My server is configured to connect insecurely. Question: How do I get it to reconnect just by using the domain example: INSECURE CONNECTION HOST: domain.com instead of typing manually My only solution is to DOWNGRADE but they say it could corrupt the database, it's a shame. PS. I don't use a secure https connection, my server is on Windows and I only asked my domain to redirect the real IP in the subdomain. I hope you can help me.
pwhodges 2023 Posted October 20, 2024 Posted October 20, 2024 What's your objection to typing https:// if that's the protocol you are using? What client are you using? I ask because in some circumstances a browser may try to force https when it is not available - this behaviour can be overridden on a site by site basis or globally in the browser settings. Downgrading from 4.8.8 to 4.8.1 would not be a problem - it's going from a beta back to the previous stable which is likely not to work. But I doubt that downgrading will do anything useful for you. Paul
Luke 42184 Posted October 20, 2024 Posted October 20, 2024 Hi, are you seeing this in the browser? It is the browsers trying to force https nowadays. I don't think you'll see anything different by using a different server version. Please let us know if this helps. Thanks.
richenginner 2 Posted October 20, 2024 Author Posted October 20, 2024 9 hours ago, pwhodges said: What's your objection to typing https:// if that's the protocol you are using? What client are you using? I ask because in some circumstances a browser may try to force https when it is not available - this behaviour can be overridden on a site by site basis or globally in the browser settings. Downgrading from 4.8.8 to 4.8.1 would not be a problem - it's going from a beta back to the previous stable which is likely not to work. But I doubt that downgrading will do anything useful for you. Paul when clients enter manually with ENTER MANUALLY IP on the TV and in the app. in the browser it is solved by disabling the secure connection. But my problem is mainly with the mobile apps and TV. it was easier for people to enter HOST: domain.com than having to type http://.domain.com now you can't just type the domain. PS. I don't use https because the configuration is too complicated for me.
Luke 42184 Posted October 20, 2024 Posted October 20, 2024 HI, you can still do that. Nothing has changed there. What server port do you use?
richenginner 2 Posted October 21, 2024 Author Posted October 21, 2024 PORT: 8104 9 hours ago, Luke said: HI, you can still do that. Nothing has changed there. What server port do you use?
Carlo 4561 Posted October 21, 2024 Posted October 21, 2024 Just curious, but why don't you get a free certificate and install it for your server so you can use https?
