EmbyPenguin 17 Posted October 18, 2024 Posted October 18, 2024 Hi, Installed the latest version of Emby on Arch. But I trhink that is not relevant as it shows the same symptoms on Emby for Android. I am talking a
Carlo 4561 Posted October 20, 2024 Posted October 20, 2024 Hi, please upload the needed information from: How to Report a Problem
EmbyPenguin 17 Posted October 20, 2024 Author Posted October 20, 2024 Hi, Thanks for your answer. My message was obviously incomplete, but the problem is, the mesages cannot be edited after some minutes anymore Anyways, I looked at the link and I have ZERO idea what I should do from there. I described my problem with my own words in another post... I can describe it here. Emby server installed on Linux. The version running is 4.8.10.0. I use Emby ONLY to serve music files and nothing else (no video). The server is started and it indexes my music and I can browse the music from Emby app or Emby on Browser. The problem is when I want to use third party software to read my music files. I want to do that because unless I am wrong, Emby "client" does not offer EQ abilities. So I would like to use a client that has EQ abilities like Neutron, USB Audio PLayer Pro (UAPP) or Shanling Eddict. All those three apps and mConnect (so 4 apps) show the same problem. Let's see what UAPP does. I launch UAPP. I ask it to search for UPnP/DLNA servers and it finds the Emby server without problems. When I select it, it asks my if I want to browse my music by Artist, Album artist or album... (among other choices I NEVER use). I ask to browse by ALBUM => no problem I ask to browse by ARTIST => it display a list of artist => I click an artist and I get "No tracks found" error mesage. I ask to browse by Album artist => it displays a list of Album artists => I click on one of those => Error message "No tracks found". Same happens with Shanling Eddict, but slightly different. I can browse by album, but not by artist. If I browse by Artist or Album artist, then the app simply quits. mConnect is maybe a little more helpful. Because if I browse by artist, it displays an icon that is not the picture of the artist but an icon like if the thing was a file... not a folder. I can tell almost for sure that this did not happen in earlier versions of Emby. I'll try to see if I can find older versions of Emby (maybe downgrade command may help here) and try to find which version works and report here whjen I find so you can investigate on what changed... Regards.
EmbyPenguin 17 Posted October 20, 2024 Author Posted October 20, 2024 (edited) Hi, As I said, I trried earlier versions of the Emby server using "downgrade" on Linux Arch. I may stress one point : it looks like on more recent versions the "Artist" or "Album Artist" is considered as a "file" and not a "folder". UAPP reports exactly "Failed to read track"... So the artist is considered as a "Track" when it indexes it seems... Now there is a SUPER weird thing. If I downgrade and relaunch the emby server, it works. BUT if on the same version, I restart the emby-server => failure again. Also something else super weird : Symfonium and Neutron player do work correctly. So maybe the problem is with the players ? That may be, but then why does it work when I re-install the emby-server and why does it stop working when I relaunch it ? The plot thickens I'll try to see if I can retrieve logs so you can see what is happening. Or make my life easier and switch to another media server... I used Neutron and UAPP's own things and they work. Regards. Edited October 20, 2024 by EmbyPenguin
Luke 42243 Posted October 20, 2024 Posted October 20, 2024 Hi, if you need immediate relief I think this is resolved on the 4.9 beta channel. We are looking into how we can backport it to 4.8. Thanks.
EmbyPenguin 17 Posted October 20, 2024 Author Posted October 20, 2024 Hi Luke, Thanks a lot for your help and answer. I'll try to see if I can find that 4.9 Beta and install it on my computer. I've seen there is a 4.9.3.apk beta for Android. I experienced problems on both computer and on Android powered streamer. So I'll try both and report Thanks a lot again. Regards. EmbyPenguin
EmbyPenguin 17 Posted October 20, 2024 Author Posted October 20, 2024 Hi, Just to mention : the Emby server for Android in beta is 4.9.0.30.apk. This is the one I am testing. So far it seems there is no packaged beta 4.9.x for Arch Linux. I checked the testing repo, it has nothing... and core repos show only 4.8.10.0 version. Not too bad because I would like to use the Android powered streamer as the main source I'll report when indexing the files is done... Takes a lot of time because there are about half of classical files and it looks difficult to retrieve relevant metadata Regards.
EmbyPenguin 17 Posted October 30, 2024 Author Posted October 30, 2024 Hi Luke, Thanks for the follow up. It seems the 4.9.0.30.apk solved the problem. I can now browse my files by album artist. So yes, it seems that at some poiint, the album artist indeed showed a trrack instead of a folder (or something the like). I will now get in touch with the developer of USB Audio Player Pro to see if he can fix two things : 1°) the pixelized cover art in UAPP (not so in other apps) and 2°) why it takes 15 seconds to display the list of 200 album artists (not so in other apps where it takes 2 seconds or so). By the way, you may wonder why I don't use the Emby client. If so, that is because, unless I have overseen it, it does not offer EQ abilities If it would I'd use that one instead 1
