aVe2000 14 Posted October 18, 2024 Posted October 18, 2024 (edited) Hello together, i browsed the forum now for an hour or so and didnt find an answer. I also played around with css. But i didnt find a way to remove collections and playlists from the left side menu. Is this still not possible? To make it clear: i have playlists and collections and i want to keep them. But how can i hide or at least collaps them? There are no options, as far as i can see. I tried with different approaches in css and didnt come to a result: how to get the data-id of the playlist? In the browser inspector only ids are shown for the items in the lists: /*[data-id="383841"], [data-itemid="383841"] {display: none !important; }*/ Is it somehow possible to get the parentid of the playlist? Maybe if take a look into the sqlite files (as far as i know its sqlite database, right)? If that is possbile, which files should i use? This one doesnt work either: /*Remove Playlist and Collection from Nav Drawer*/ /*Note if Nav Drawer is pinned this code will cause issue in Dashboard Drawer also*/ div.mainDrawer.drawer-open div:nth-child(4):not(.drawer-docked div:nth-child(4)), div.mainDrawer.drawer-open div:nth-child(5):not(.drawer-docked div:nth-child(5)) {display: none;} There was another suggestion like the first one with navDrawer title="playlists" (or maybe for my german version "Wiedergabelisten") which didnt work, either. I am new with emby coming from plex and after all i am very happy with emby. So, no pressure. I just want to make sure i didnt miss anything. Kind regards Edited October 18, 2024 by aVe2000
Solution visproduction 335 Posted October 18, 2024 Solution Posted October 18, 2024 (edited) Try this: .mainDrawer.focuscontainer.padded-bottom-page.emby-scroller.scrollY.scrollY-mini.scrollFrameY.flex-direction-column.drawer-open > div > div:nth-child(3) > div > button:nth-last-child(2), .mainDrawer.focuscontainer.padded-bottom-page.emby-scroller.scrollY.scrollY-mini.scrollFrameY.flex-direction-column.drawer-open.drawer-docked > div > div:nth-last-child(2) { display:none; margin-bottom: -36px !important; } Edited October 18, 2024 by visproduction 1
worthmo 12 Posted January 27 Posted January 27 Does this solution still work? I added the above to my custom css but I still see the playlist menu expanded each time I login.
