G60s Pro remote, button remap.
I'm hoping someone here can point me in the direction of a solution for this.
Ive recently brought a G60s Pro airmouse remote, which works wonderfully with one glaring flaw, the OK button in the middle of the device does not pass the enter button to Emby, so cant be used to select items. It works as left click when in airmouse mode, but not as enter when outside airmouse mode which makes it very inconvenient to use (I could flip it upside down and use the enter key on the keyboard side, but thats pretty horrible to use). This is running in windows using Emby theatre, it seems this remote is aimed at streaming boxes mostly and the button may work correctly there.
I have had a look at the output with a USB analyzer and it shows this button is "menu pick", part of the consumer control section of the HID specs.
I would like to remap this to the enter key, but no remapping tools I can find detect the "menu pick" input. Autohotkey looks promising but is bloody complicated to use, I am hoping there are some AHK wizards floating around who could help with that, or someone might have another suggestion before I dive in and try to learn AHK.
  • 2 weeks later...
Solved with a bunch of hacked together AHK sample scripts.
Hi, thanks for following up.
  • 1 month later...
Hi SMLK, how you solved problem with g60s pro?
Messaged.
  • 4 weeks later...
Hi SMLK, same problem could you please help ? very new into this world, no idea what AHK scripts are...
Thanks a lot
Edited by H3USS
Thanks a lot
Messaged.
  • 2 weeks later...
